Summary Win Explorer Thumbnails & PSP
Linda Lou
processor: Intel i7vPro10th Gen
Hard_Drive_Capacity: 1024 GB
Monitor/Display Make & Model: ThinkPad Extreme Gen3
Corel programs: PaintShop Pro 7, 8.1, 2018, 2023
Re: Summary Win Explorer Thumbnails & PSP
Post by Linda Lou »
ehume wrote:it turns out, if you add a single extension type, it will complete successfully.
Does that mean when using File>Preferences you must associate PSP with no other file associations other than the default .pspimage?
I had to install PSP 8.1 on a new computer and am having the thumbnail/image view problem on that as well as with PSP 2018 on another computer.
I'd really like to fix it in both cases.
ehume
processor: i7 4770k
sound_card: no_sound_card
Post by ehume »
I'm sorry, but my last post on this issue was Aug 2019. I have gotten old enough that I no longer remember . . .
Linda Lou
Post by Linda Lou »
ehume wrote: I have gotten old enough that I no longer remember . . .
That's ok. I just needed to take a break from the computer for a few hours before I could wrap my brain about the best way to proceed..
In my case it is not a One Drive issue because OD was removed before PSP was installed. If I remember correctly OD's problem was that all image files had icons. That was something different
To be more specific:
For the computer with PSP 8.1, the problem is that PSP 8.1 is not showing .pspimage files when browsing and is reporting "Not a valid PSP image" for PSP images that were created by Corel 2018. I just don't want to have to save everything as a .png or .jpg if I am working on a project that I need layers for.
Is it just not possible to use layered images between both versions?
Editing to update that after some rest, I re-registered the .dll for PSP 2018 and I can now see Thumbnails of images created with 2018. I still have the above problem on 8.1, however.
patara
motherboard: ASUS Prime Z690 DDR5
processor: Intel i7-12700K CPU 12 Core
ram: 32 GB
Video Card: GeForce GTX 1060 GI Gaming 6G
sound_card: VIA High Definition Audio
Hard_Drive_Capacity: 1TB SSD +22TB Hard Drives
Monitor/Display Make & Model: Dell U2715H
Corel programs: PSP7 to PSP 2023
Post by patara »
Linda Lou wrote: the problem is that PSP 8.1 is not showing .pspimage files when browsing and is reporting "Not a valid PSP image" for PSP images that were created by Corel 2018. I just don't want to have to save everything as a .png or .jpg if I am working on a project that I need layers for.
Editing to update - I still have the above problem on 8.1, however.
Linda you can save layers in PSP 2018 as a PSP 8 compatible file so that the file will open in that version.
The different versions you can save as is under Options in the Save Dialog box.
But when doing that your layers can't use any of the newer things available e.g.styles etc.
Linda Lou
Post by Linda Lou »
Thank you! I'll definitely try that. :D
