VS 2019 "Scorefitter" Music volume not adjustable.
JWolters
motherboard: MSI Z170A GAMING PRO CARBON
processor: Intel Core i7-9700K
ram: 32GB-3200
Video Card: NVidia GTX 1060-6GB
sound_card: Lumix FZ2000 and GH5 and BMPCC4K
Hard_Drive_Capacity: 20TB-SS+HD
Monitor/Display Make & Model: 2x ASUS UHD
Corel programs: PS 24U, VS 2020, 3rd party
Post by JWolters »
Hi.
I want to adjust the volume of "scorefitter" music. I choose a certain percentage. Again and again, this value jumps back to 100%. This does not happen with other audio sources. Is that known?
So the question of a forum member.
Thanks.
Regards Hansi
my independent website
Re: VS 2019 "Scorefitter" Music volume not adjustable.
I don't normally use Scorefitter music. But I have just opened it and added a piece to the music timeline. I also added an mpeg-4 video to the main timeline. When I select/highlight the music clip, I can access the volume control: see image.
I lower the volume from the default 100 to what is shown (red arrow -- 56). I play the clip in Clip mode and the level stays at 56. I adjust the view to Project mode and I lose sight of the volume control. But when I play the project in Project mode, the music appears to stay at the lowered rate.
It might be helpful if your user could describe in a little more detail exactly what he/she is doing.
JWolters
ram: 32GB-3200
Post by JWolters »
Hi Ken and thanks for your response.
I could understand the problem of the user. He is concerned with readjusting the sound volume on the timeline. In my example, I too could circle the mistake. Example as follows,
Original sound, scorefitter music, sample music one soundtrack each. Further procedure: right mouse click on the track to be set, in the context menu select "Adjust volume". Continue to set new parameters and save. Reopen "adjust volume" and check parameters. O-Ton and also sample music have kept the new parameters whereas Scorefitter jumped back to 100%.
Watch my short animation. https://youtu.be/3XcKJuhfYRQ
Regards Hansi
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
in X9 the same, but not if you on sound mixer view, there it will stay at your %.
But the best way in using Scorfiter is to use the actual wav file and not as is. that way one free to use/trim it as any other sound file.
Panasonic X900m, VXF1
JWolters
ram: 32GB-3200
Post by JWolters »
I have to keep on threading and come back to Ken. A sound track volume with right mouse button and further in the context menu is the one option and should work. Also for scorefitter.
Opening the Sound Editor with a double-click on a sound track content is a second thing - and has success. And with that we are at Ken sample above. If the volume parameters are changed there, they retain their value. Even after restarting CVS2019.
Guys, thank you for the successful discussion. But the setting in the context menu still remains a bug and has been reported.
Regards Hansi
