After new text deselected, only outline visible.
Killer133
processor: HP Hexa-Core 2.0GHz 2.00 GHz
Hard_Drive_Capacity: 950GB
Post by Killer133 »
I have been adding some text to an image and it appears ok when I'm typing, but once I deselect the text it changes to be just a dotted outline.
I've been successfully creating text most of the morning, don't believe I've changed anything that would make this occur, but . . .
I've attached an image with screengrabs showing "as I'm typing" and after what's left after deselecting: you can just about make out the outline in the lower part of the image (I zoomed in on the lower example, to try and allow the text to be seen).
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: After new text deselected, only outline visible.
Post by hartpaul »
Where it says Create as , change from Selection to Vector.
Wherever you have just a tool malfunctioning or not doing what you expect of it , reset that tool to its default. This Reset to Default is found for most tools to the right of the drop down Presets dialog.
Killer133
Post by Killer133 »
hartpaul wrote:Where it says Create as , change from Selection to Vector.
Thank you! I thought I'd tried all those options under Create As, but obviously not. It was driving me absolutely mad :lol:
And thanks for the reset tip - that's what I'll try first, if anything is not reacting as I expect.
