Hello,
Recently, while working with VS Ultimate 2019, the program suddenly has been closed. The computer didn't freeze, just like nothing happened.
It happened to me several times. Any suggestions what should be done?
Thanks,
Abraham
VS Ultimate 2019 closed
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Re: VS Ultimate 2019 closed
Since at least X10, VS has been notorious for silent crashes during editing and whilst rendering (see viewtopic.php?f=1&t=62625).zehavi wrote:while working with VS Ultimate 2019, the program suddenly has been closed. The computer didn't freeze, just like nothing happened.
If VS silently crashes during editing then I simply reopen the VSP and continue editing until the next silent crash. If VS2018 silently crashes whilst rendering then I save the VSP in the X8 format and open that in an early version of VS for rendering.zehavi wrote:Any suggestions what should be done?
tletter
zehavi
- processor: Intel[R] Core[TM] i7-8700 CPU 3.20 GHz
- Hard_Drive_Capacity: 465 GB
- Monitor/Display Make & Model: LG
Thank you tletter,
I have read the viewtopic you sent me.
So as the version of the program is higher, it becomes less reliable?
I wonder if Corel is aware to this phenomenon.
tletter
That's my experience with VS2018 and VS2019.zehavi wrote:So as the version of the program is higher, it becomes less reliable?
Undoubtedly Corel knows as they frantically issue numerous large SPs. However that doesn't seem to bother Corel as their objective appears to be adding features at the expense of stability and reliability.zehavi wrote:I wonder if Corel is aware to this phenomenon.
tletter
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
זהבי,
set your auto save to 1 min and hope for good.
Stability is old fashion, now new bells make more noise.
Panasonic X900m, VXF1
tletter
My approach is not to rely on AutoSave rather to manually save after every single change made which prevents the loss of any work when VS silently crashes. I've also experienced VS saving a VSP and then subsequently being unable to reopen the saved VSP. Hence you might want to ensure that you have a functional VSP at the end of a day's work which can be done by saving the VSP as in an older format as well, e.g. saving a VS2018 VSP as a X8 VSP even though there maybe some loss of features.asik1 wrote:set your auto save to 1 min and hope for good.
tletter
zehavi
Thank you tletter and asik1 for your useful advices.
At least I am happy that this is not a problem related to my personal program or computer.
