Good to be reading about all of these improvements!-Raptor- wrote:
Effects Manager
The effect manager solves one of the biggest problem of older version of Mediastudio..
With MSP 7, when using a filter, in the filter preview window you see the effect of that filter.. but applied to the original footage. If you apply two or more filter.. you can only "guess" what will be the result..
Now in MSP 8, the problem is not only solved, but you can also "hide" a filter with a mouse click. Well done Ulead
Do we have control over the order in which the filters are applied? That is, are the filters applied in order, top to bottom and are there now buttons to change the application order?
Maybe I don't know how to use MSP7 well enough yet ... For example, I want to make sure that Noise Reduction is applied before Unsharp Mask. If applied in the other order, the results are quite different (and bad). Is there a way to enforce that today? If not, does the MSP 8 beta have it?
Has the 'granularity' of the filters been improved? Lots of audio and video filters in MSP 7 have too few acceptable values and a big jump in effect between values, e.g., audio noise reduction. Also, we're missing all kinds of 'basic' filters (like - eliminate AC hum - or better, a particular Hz range).
Thanks!
Karl
PS If I download the beta, will it interfere with my existing MSP 7 settings, or can it live gracefully alongside? Any problems for you?
