How cut all outside a mask selection
aldobz
processor: INTEL I7
Hard_Drive_Capacity: 250GB
Corel programs: PaintShop Pro 2019 Ultimate
Post by aldobz »
Hi everyone,
after three days of unsuccessful attempts I am asking for help here. What I want to do is circumscribe an image with an irregular outline (not a circle, not an ellipse, not a rectangle), then select the outline and, with a command, clean up everything outside the selected contour.
I have seen that this is possible using predefined vector images or text. In fact in this case just use the "cutter preview" command followed by "shape cutter". I would like to make the same "cut". I'm using PaintShop Pro 2019 Ultimate, and of course the shape I've drawn for cropping is on a vector layer. Any help is welcome.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: How cut all outside a mask selection
Post by hartpaul »
Again it would be good if you could post an example of your starting image and then the final image that you want. You appear to have suggested that you want something like the shape cutter tool.
In the absence of seeing what image you are referring to and what you want done I am guessing the following.
1. Make your selection using a suitable selection tool. This image shows my settings.
01using lassoo tool .jpg (70.88 KiB) Viewed 1750 times
2. Right click in your layers palette and choose Promote Selection to layer
which gives you this
In this case I turned off the visibility of the background layer but that is unneccessary.
3. Drag the thumb of the promoted selection to the workspace.
Now using a mask can be another way but a bit more involved
aldobz
processor: INTEL I7
Post by aldobz »
hartpaul wrote:Again it would be good if you could post an example of your starting image and then the final image that you want. You appear to have suggested that you want something like the shape cutter tool.
Hartpaul, many thanks for your answer and for your time you wasted for me.
I presented my problem without near details, and in fact almost wrong.
Here a bit of details:
I have two vectors
a background
and this is the merged result
what I need, is to cut off all outside the vector lines.
In the meanwhile I found a workaround, but not simple: I changed the lines color to white, changed the background form transparent to white, then clicked the "text" button, and so appeared on the bar the Shape Cutter. Clicking the shape cutter, the NOT white color masked area will be erased.
Sure gives a easier and faster method.
Do you can suggest me somewhat?
Many thanks for your support.
Sorry for my bad english, and regards from Italy
Aldo
hartpaul
ram: 8 Gb
Post by hartpaul »
OK you have a vector shape like a shield on a separate layer over a landscape and you want to remove the background so that it looks like the image is painted on the shield.
Easy
I am not that familiar with drawing vector shapes with the pen tool so I used the preset shapes tool which also has a shield shape available.
1. I chose the preshape tool and from the shape list beside the Presets chose the shield.
2. Drew the shield over my bird layer and moved it into position.
3. Choose the magic wand tool and clicked outside the shield so everything outside the shield is selected.
4. Right click the Background layer in the layer palette and choose Promote Background Layer. This changes it to a raster layer.
5. Now with the background layer chosen press the Delete key on your keyboard. Then do Selectione > Select None
Is that what you are after?
aldobz
processor: INTEL I7
Post by aldobz »
No, dear hartpaul.
When I use the magic wand, only small areas of my raster are selected. This was my initial problem. Probably it depends on the selection correspondence, ie "RGB value", "color", "traditional" etc.
I am also amazed that you can choose a shield among the predefined shields. :shock:
How many do you have? I only have 10 ... :cry:
hartpaul
ram: 8 Gb
Post by hartpaul »
Just tried it with your image. Works fine. Using the magic wand you must have the upper vector layer active.
And there is only one shield vector that comes with PSP. You may have constructed and or downloaded others , but I only have 1 preset shape shield.
aldobz
processor: INTEL I7
Post by aldobz »
Hi hartpaul,
i tried anoteher time, and paid attention to have the vector layer active.
This is the result
Regarding the installed vector shapes, i have only these defaults
Where do I can download more shapes from?
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
aldobz wrote: Where do I can download more shapes from?
Click on your account on Corel's website.
You will access to content you earned when you bought the program.
Jean-Luc
Post by Jean-Luc »
(deleted)
hartpaul
ram: 8 Gb
Post by hartpaul »
When you use your magic wand you must untick "Use all layers" so that it only operates on the vector layer . This works with all match modes except Opacity. I also had "Contiguous" ticked.
Further to what Jean-Luc said you are looking for the file
PSP2019_Corel_CreativeCollection
Download and install that.
aldobz
processor: INTEL I7
Post by aldobz »
hartpaul wrote:When you use your magic wand you must untick "Use all layers" so that it only operates on the vector layer . This works with all match modes except Opacity. I also had "Contiguous" ticked.
GREAT!!! Finally I made it ... One of the problems was that the "homemade" shield was made up of four vectors, which however must be merged into a group, so as to represent a single vector.
Another problem was that I had "use all layers" ticked.
As a novice, I am learning a lot thanks to you.
hartpaul wrote: Further to what Jean-Luc said you are looking for the file
Thanks again to Jean-Luc for the tip regarding the Creative Collection, which I had in the meantime identified, among the various files downloaded, such as the one containing additional tools.
Thanks again to both of you for your kindness and willingness to help.
hartpaul
ram: 8 Gb
Post by hartpaul »
No problems. Just another tip . You said that you found the Creative Collections in the group of files that you had downloaded. Also make sure that you have at least one more backup folder containing all those files and also on a separate hard drive or separate computer. You never know when you will get a failure of the single drive that contains all your backup files.
aldobz
processor: INTEL I7
Post by aldobz »
hartpaul wrote:No problems. Just another tip . You said that you found the Creative Collections in the group of files that you had downloaded. Also make sure that you have at least one more backup folder containing all those files and also on a separate hard drive or separate computer. You never know when you will get a failure of the single drive that contains all your backup files.
Thank you Hartpaul for the tip. With PSP I am a newbie, but i work in informatics since several years. I have a QNAP "NAS" (Network Attached Storage) with two disks RAID configured, where i store all my important data.
Thanks anyway for the tip, and greetings from Italy.
