NewBlue lower thirds title issues
railroadguy
motherboard: Acer Aspire TC-1770
processor: ntel 13th Gen Core i5-13400
ram: 32 Gb
Video Card: NVIDIA GeForce GTX 1050 Ti
Hard_Drive_Capacity: 1 Tb SSD
Monitor/Display Make & Model: Acer AL2251W
Corel programs: Corel Video 2023 Ult
Post by railroadguy »
I am doing something really stupid with NewBlue lower thirds. I have a 3 minute video on the time line. I add NewBlue Title to the video. I select the title "Blue Slide" and add the text. The title runs 6 seconds but when I close NewBlue the title appears and stays the whole 3 minutes. I can't see any way to have it appear and disappear within the 6 seconds specifies in NewBlue. What am I doing wrong?
The only way I can see to do this, and it may the right way is to use the scissors and cut the first 6 seconds of the video and then use that part for NewBlue. Is that the way it works?
Thanks,
Dan
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: NewBlue lower thirds title issues
Post by RobertOZ »
You may find BCC Title Studio is a better alternative, seems to have more available features
railroadguy
ram: 32 Gb
RobertOZ wrote:You may find BCC Title Studio is a better alternative, seems to have more available features
It may have but it crashes. Even if I just put a object on the timeline and make it 10 seconds. I then drop the BCC Title Studio on top. Then I go to customize and select a lower third, Badge Slide Blue, in my case. I need to move the elements over to the right so I switch to Advanced UI and the second I try and move the selected element, the badge in my case VideoStudio crashed. No warning just disappears/closes.
Thanks,
Dan
RobertOZ
Post by RobertOZ »
You haven't actually told us what version of VS you have installed, however, in the past when I have had similar issues with BCC Title Studio, I uninstalled BCC from programs and features then reinstalled from the Bonus Features folder, that fixed the issues
RobertOZ
Post by RobertOZ »
Also watch the following tutorial which shows the correct way to use BCC
https://learn.corel.com/tutorials/creat ... animation/
railroadguy
ram: 32 Gb
Thank you. It helps to see things rather then read about them. This worked well.
Thanks,
Dan
