1. The recording has been done: a subject with several concurrent cameras recording wide-angle face on, side on and close up shots including sound in-camera, and a separate (single) external audio recording of the whole proceeding, including clapper board for any repeats. The recording duration is about 20 minutes.
2. The students will have copies of all the camera and audio files, and be required to edit the files from the cameras and audio recorder to produce a reasonable video clip of the event that's about 5-8 minutes long demonstrating a grasp of using MCE within VideoStudio.
So, the question about technique is about editing any of the video files and the related audio recording, specifically about maintaining sync when doing that, noting that that MCE has provisions for cameras and audio files in the MCE panel
- synching the video and sound at the start of each clip is easy enough - the clapper board is there for that
- maintaining video and external sound synch when editing the video clips - generally to reduce the time/length of clip - is a possible problem. Editing the video clips in MCE is highly likely (?) to get out of sych with the external audio: cut n trim of a video clip is usually effected independently of other tracks inc audio. Would it be better to:
a. edit in MCE, and if so how to maintain sync with external audio files when trimming discrete clips; or
b. edit each clip separately and maintain audio sync manually;, render and then insert the result into MCE
c. ignore the external audio and rely on the integral audio in each video clip, which would result in editing audio at the same times/places as any edits made to the video
