In Help / About, the version is 21.1.0.22
In Windows Explorer, the version is displayed 21.0.0.1
CCleaner says there is a new version but unable to install Update 1 because PSP says "already installed".
PSP 2019 versions ?
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
PSP 2019 versions ?
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: PSP 2019 versions ?
If Help>About shows version 21.1.0.22 then you do have the latest (and only) update that has been released for PSP 2019, which is why you would be unable to install it again. I don't know why Windows Explorer doesn't show the update version, but that could be something to do with the update installer simply not updating the proper registry entry with the new version number. And of course CCleaner will read the version number as it is shown in the registry, so that will indicate that there is a new update available when, in fact, you already have that update installed.
JoeB
Using PSP 2019 64bit
JoeB
Jean-Luc
This was asked in the French Forum when someone tried to install the HotFix (published 23rd of January). He was confused...JoeB wrote:If Help>About shows version 21.1.0.22 then you do have the latest (and only) update that has been released for PSP 2019, which is why you would be unable to install it again. I don't know why Windows Explorer doesn't show the update version, but that could be something to do with the update installer simply not updating the proper registry entry with the new version number. And of course CCleaner will read the version number as it is shown in the registry, so that will indicate that there is a new update available when, in fact, you already have that update installed.
The Update 1 should have corrected the version number...
- ehume
- motherboard: Gigabyte GA-Z87X-UD4H
- processor: i7 4770k
- Video Card: Intel HD4600 [iGPU]
- sound_card: no_sound_card
- Hard_Drive_Capacity: 512GB+4TB
- Monitor/Display Make & Model: Acer KN242HYL
- Corel programs: PSP 2018 32b & 64b, AS3 64b, PE5 64b
I wonder where in the Registry it is.
JoeB
- ram: 8 GB
You should be able to find it if you open the Registry Editor, then click on the arrow to open the HKEY_LOCAL_MACHINE folder, then right-click on the SOFTWARE folder that's within it and click the Find option in the context menu that opens. Type 21.0.0.1 in the search box and it will search for that string and show you the first path it finds. Hitting F3 after that will search for the string in other locations further down the tree.
JoeB
JoeB
Radim
- ram: 4GB
- Monitor/Display Make & Model: 27 inch
There are two version info in EXEs/DLLs etc. in Windows:
1. File version
2. Product version
..It can differ, is can be the same, or one usually "File version" is not set.
1. File version
2. Product version
Jean-Luc
Thank you Radim.Radim wrote:There are two version info in EXEs/DLLs etc. in Windows:
1. File version
2. Product version
I just tested with PSP 2018 and I observe the same "difference" :
- ehume
What does Help > About tell you within your app?Jean-Luc wrote:Thank you Radim.Radim wrote:There are two version info in EXEs/DLLs etc. in Windows:
1. File version
2. Product version
Jean-Luc
The correct version is displayed within the app.ehume wrote: What does Help > About tell you within your app?
But when using CCleaner and searching for program udpates, CCcleaner says "A new version exists for PSP".
Following this suggestion, it is not possible to install the new version (PSP says "already installed"). This produces confusion ...
