Applying script on loaded pic different to batch processing?
pstein
Corel programs: PSP X2
Post by pstein »
Once again I experienced a strange result in script execution:
At first I loaded a photo *.jpg image with a size of 2072 kb into PSP and executed the script (shown at the bottom) directly from script toolbar.
The script is simple: Just resize, saturate, sharp and save
The result is a file of size 1455 KB.
Fine so far.
Now I went in PSP to menu File-->Batch process, then browsed to a copy of the original *.jpg photo file, then selected
the mentioned script from the drop-down and finally clicked on "Start" button.
Much to my surprise the resulting file has only a size of only 493 KB!
Why? Shouldn't it be the same resulting file size as direct execution for loaded pic?
Does Batch processing of a script use another compression factor as processing for loaded pictures?
Is there a way to set the compression factor as function directly in script file?
Thank you
Peter
Code: Select all
from PSPApp import *
def ScriptProperties():
    return {
        'Author': u'',
        'Copyright': u'',
        'Description': u'',
        'Host': u'Paint Shop Pro Photo',
        'Host Version': u'12.01'
def Do(Environment):
    # EnableOptimizedScriptUndo
    App.Do( Environment, 'EnableOptimizedScriptUndo', {
            'GeneralSettings': {
                'ExecutionMode': App.Constants.ExecutionMode.Default,
                'AutoActionMode': App.Constants.AutoActionMode.Match,
                'Version': ((12,0,1),1)
    # Resize
    App.Do( Environment, 'Resize', {
            'AspectRatio': 1.33333,
            'CurrentDimensionUnits': App.Constants.UnitsOfMeasure.Pixels,
            'CurrentResolutionUnits': App.Constants.ResolutionUnits.PixelsPerIn,
            'Height': 1440,
            'MaintainAspectRatio': True,
            'Resample': True,
            'ResampleType': App.Constants.ResampleType.Bicubic,
            'ResizeAllLayers': True,
            'Resolution': 300,
            'Width': 1920,
            'SharpnessValue': 50,
            'AdvancedMode': True,
    # Color Adjust HSL
    App.Do( Environment, 'ColorAdjustHSL', {
            'HSL': {
                'Colorize': False,
                'Master': (0,12,0),
                'MasterColorize': (0,0,0),
                'Red': (0,0,0,315,345,15,45),
                'Green': (0,0,0,75,105,135,165),
                'Blue': (0,0,0,195,225,255,285),
                'Cyan': (0,0,0,135,165,195,225),
                'Magenta': (0,0,0,255,285,315,345),
                'Yellow': (0,0,0,15,45,75,105)
    # Sharpen
    App.Do( Environment, 'Sharpen', {
    # FileSave
    App.Do( Environment, 'FileSave', {
                'AutoActionMode': App.Constants.AutoActionMode.AllAlways,
            'DefaultProperties': []
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Applying script on loaded pic different to batch process
Post by LeviFiction »
Don't use a script that saves the file in a batch process. The batch process command handles the saving for you. There should be an option in the output settings to set the save parameters including the compression level.
pstein
Post by pstein »
LeviFiction wrote:There should be an option in the output settings to set the save parameters including the compression level.
Hmm, where do I find this option EXACTLY?
I found neither one in dialog when saving the just recorded script nor in the batch process dialog.
See attached snapshots.
How can I specify the compression factor manually/textually in script file?
Peter
ram: 6 GB
Why you want to overwrite and destroy your originals I will never understand.
To manually set the compression of a batch without using a script
1) Select New Type
2) Choose JPG inType
3) Hit Options - Set Compression
4) Leave everything else blank it'll overwrite.
IF you must use a script to do the saving, use Save As to set the compression in the script and set Batch Process to Script Save. NOT Overwrite.
1) When recording the script use Save As and set the compression level
2) Open the script in a text editor
3) Edit the script and change the FileName parameter to be App.TargetDocument.Name
4) Save the script
5) Open Batch Process
6) Set Use Script and Silent Mode
7) Set Script Save
8) Add Images and run batch
The script will do the saving, SaveAs will set the compression, and using App.TargetDocument.Name will overwrite the image by using the full image path. And since it's run in silent mode it won't ask for permission.
Here is an example of the SaveAs command set with a compression level of 8, and using App.TargetDocument.Name as the filename
Code: Select all
    # FileSaveAs
    App.Do( Environment, 'FileSaveAs', {
            'Encoding': {
                'JPG': {
                    'Variant': App.Constants.JpegFormat.Standard,
                    'CompressionFactor': 8,
                    'ChromaSubSampling': App.Constants.ChromaSubSampling.YCC_1x1_1x1_1x1,
                    'EXIF': True,
                    'EmbedJPGICC': True
            'FileName': App.TargetDocument.Name,
            'FileFormat': App.Constants.FileFormat.JPG,
            'FormatDesc': u'JPG JPEG ',
                'Version': ((12,5,0),1)
