I want to add my name plus "Photography" at the bottom of many JPEGS which I then wish to publish online.
Is there a tutorial showing how to do that in PSP2019 Ultimate without having to enter the text over and over again hundreds of times please?
I'm sure there is but I have looked and looked and can't find anything.
Thanks.
Adding my name plus Photography at the bottom RH corner
Phil47
- motherboard: ASUS Z170-P DDR 4
- processor: i-5 6600K OC
- Video Card: GTX960
- Hard_Drive_Capacity: 500GB
- Monitor/Display Make & Model: Asus MX279
- Corel programs: PSP X6 PSP X9 PSP 2018
Tell the truth....but gently.
Phil.
Phil.
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: Adding my name plus Photography at the bottom RH corner
-> File
-> Add Info
-> In Caption, write your text (select font, size, color, ...)
-> In Position, tick bottom right
-> Modify Offset X and Y
-> Apply
-> F3 (History)
-> Select Add Info in History
-> Right-click and Apply to other open documents
-> Add Info
-> Apply
-> F3 (History)
Phil47
Thanks very much.
Phil.
Phil.
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
That does work, but if you want the font to be the same size in relation to the pixel size of the images, then I believe that the images must all be the same pixel size and the same print resolution to start with.Jean-Luc wrote:-> File
-> Add Info
-> Apply
-> F3 (History)
JoeB
Using PSP 2019 64bit
JoeB
Jean-Luc
JoeB is right about the same PPI needed for all images.
Another method, PPI not dependent :
-> Create your text on a transparent layer.
-> Save it as PNG (retaining the transparency).
-> Image
-> Warermarking
-> Visible Watermark
-> Watermark source : load your text/PNG image
-> Placement : Lower-Right
-> Style : select what you want.
-> Image
-> Warermarking
JoeB
- ram: 8 GB
Good one, Jean-Luc. And, of course, then use the History to Apply to Other Open Documents as per your first post.
JoeB
JoeB
