Ditto on this. I just went from X9 to 2019. 2019 simply closes with no explanation. I will usually try again 1-2 more times, eventually it's successful. NEVER, EVER did X9 close or crash.2019Pro keeps crashing if I click on a transition I've put on the video track to adjust its length.
So many issues with Video Studio 2019
steveoregon
- processor: i7 6700K 4Ghz
- Video Card: Nvidia GeForce GTX 970
- Hard_Drive_Capacity: 2TB
Re: So many issues with Video Studio 2019
pepegota
- motherboard: ASUS TUF Z390-Plus
- processor: Intel i9 - 9900k
- ram: 64 GB
- Video Card: GTX 1660 6GB
- sound_card: On board sound
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Ben Q, "21" LCD
- Corel programs: VS 2018, VS 2019, VS 2020
I accidentally placed a chapter mark on and could not remove it. The computer locked up. This would be a good program if they just removed the bugs for 2020. I completed the project in Power Director without issue. VS has a better work flow than PD, but only when it works, else a constant save is required.
BurnUnit
- motherboard: BIOSTAR Group A780L3B
- processor: 2.80 gigahertz AMD Phenom II X4 830
- ram: 4GB
- Video Card: onboard
- sound_card: onboard
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung 941BW
- Corel programs: VideoStudio ProX10
I know this is an older post, but just in case someone else is having the same problem adding a Fade to Black or other transition to the end of their video;
Try adding a black background segment to the end of your video first, maybe 3 to 5 seconds in length. Then add your transition between the end of your video and the black background. If you're using a 3 second transition it will affect the last 1 1/2 seconds of your video clip and the first 1 1/2 seconds of the black background clip. To work properly the transition has to affect a bit of both clips.
I assume your clips are on the top video track
Are you sure there is not a separate clip maybe 1 frame long, this can occur if you have used Freeze Frame on the last frame of a video file and difficult to see
Switching to Storyboard View will display the top track as thumbnail, each showing their duration.
