Apply a script to a whole folder/to all current loaded pics?
pstein
Corel programs: PSP X2
Post by pstein »
How can I apply an existing script to all pictures of a certain folder (e.g. in D:\pictures\2019\)?
How can I apply an existing script to all currently loaded pictures?
Thank you
Peter
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Apply a script to a whole folder/to all current loaded p
Post by LeviFiction »
1) Applying a script to all images in a folder
Use Batch Processing
File -> Batch Process
Add your images from the folder
Add a Script action, or choose from a set of other preset actions
Choose how to save out the result, as copies or overwriting the originals
There is also a script by SuzShook (a previous scripting Guru) on using a trusted script to edit all of the images in a folder. The difference is the a script will load an image into the editor which is a slower process than how batch process simply loads the image into memory.
2) I don't believe there is a built-in option for this. But the manual scripting is easy enough. You simply need to loop over all of the documents using the RunScript command on each one.
Here is a very rough code example, not a full script.
Code: Select all
from PSPApp import *
def ScriptProperties():
    return {
        'Author': u'LeviFiction',
        'Copyright': u'2019',
        'Description': u'Run Script on all open images',
        'Host': u'PaintShop Pro',
        'Host Version': u'9'
def Do(Environment):
    for doc in App.Documents:
        # RunSelectedScript
        App.Do( Environment, 'RunSelectedScript', {'ScriptName': u'Mosaic'}, doc)
So in this script, I used Python's for loop to go through the list of all open documents which PSP provides in the variable "App.Documents" placing each Document object into the variable "doc"
Then for each document, I run the "RunSelectedScript" command. Using the "doc" variable as the final parameter of the command. This tells PSP which document to run the command on.
