jerky pictures
hotham26
jerky pictures
Post by hotham26 »
Hi there - neewbie here. Just tried to make my first DVD, but the resulting DVD has really jerky pictures when there is movement on the screen (there is quite a lot of movement in the video, so it is really jerky!).
I exported a QT movie from Avid DV Xpress Pro (upper field first as am working in PAL), and then imported this to MF4. I set the mpeg settings to 7000 kbps and to the Best Quality setting.
Is there something in MF4 which is causing this to happen, or is it my original QT movie? If I use the Discreet Cleaner to encode the QT movie into another format, it seems fine, so it suggests to me it is a setting within MF4.
Any help would be greatly appreciated ! Many thanks...
HVCVIDEO
Post by HVCVIDEO »
i have a plextor dvd writer and afetr the softupdate from 4.01 to 4.02 i have the same problem, still's are ok but with moving pictuers there are troubles on the top of the tv screen. so i did compleet uninstall of mf4.02
er reeinstall 4.0 and everything works fine again, hope this helps you
Hervé
