Experiment for Version 3
pwllderi
Post by pwllderi »
Select 1Gb of photos and transfer them into Version 3
What is the resultant total Gb??--[my result 6Gb]
Remove all the 'options' that you can with v3 [music, transition etc]
Now what is the resultant total Gb??--[my result 4Gb]
Is that the smallest file you can get for the initial 1Gb of photos?
With all options set to the base and using version 2 - the smallest file Ican get for the initial 1Gb of photos is 238MB, and I can complete the disk [in 25 minutes] and view it successfully!!!!!!!!!!!!!!!!
The playback varies according to Playback machinery and TV.
angrakiller
Post by angrakiller »
Have you installed the 5in1 patch? This will correct the problem of wrong calculated required space.
After patched, I try a project with 1.12 GB source files and the required space shows 1.12 GB.
pwllderi
Post by pwllderi »
angrakiller wrote:Have you installed the 5in1 patch? This will correct the problem of wrong calculated required space.
Thank you,
It was just as you said.
