Should I delete PSP2018 as I now have PSP2019?
Phil47
- motherboard: ASUS Z170-P DDR 4
- processor: i-5 6600K OC
- Video Card: GTX960
- Hard_Drive_Capacity: 500GB
- Monitor/Display Make & Model: Asus MX279
- Corel programs: PSP X6 PSP X9 PSP 2018
Is it the done thing to delete the earlier software to make more space on the disc?
Tell the truth....but gently.
Phil.
Phil.
- ehume
- motherboard: Gigabyte GA-Z87X-UD4H
- processor: i7 4770k
- Video Card: Intel HD4600 [iGPU]
- sound_card: no_sound_card
- Hard_Drive_Capacity: 512GB+4TB
- Monitor/Display Make & Model: Acer KN242HYL
- Corel programs: PSP 2018 32b & 64b, AS3 64b, PE5 64b
Re: Should I delete PSP2018 as I now have PSP2019?
I have a total of 14 versions of PSP on my Win10 machine, not counting 32-64-bit splits. They don't take up a lot of room, and I can check on the earlier versions easily. The difference between the UI of PSP 2019 and PSP 2018 are not as large as the differences between PSPx9 and PSP 2018 -- PSP 2018 was when the devs transitioned from rotating the Clip box (PSPx9 and before) to rotating the whole image (PSP 2018 and later). The only meaningful difference seems to be that you can change your app's text size in PSP 2019.
Bottom line: it probably makes no practical difference if you keep 2018 or not. YOU might keep PSP 2018 for sentimental reasons.
