Rotopen
mwsing
motherboard: Dell Inc 0C2KJT A00
processor: 2.93 Gigahertz Intel Core i3 530
ram: 6 gigabyte
Video Card: NVIDIA GeForce310
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: Viewsonic VX2240W
Rotopen
Post by mwsing »
How do I make the symbol in Rotopen point in the direction of travel. I know I did this before but cant seem to see how it works in the 2018 version.
BJC
Hard_Drive_Capacity: 1TB
Corel programs: Videostudio X10 and 2020
Re: Rotopen
Post by BJC »
There was a discussion a few years back about adding extra icons to the rotopen library - somewhere in the middle of the discussion is the location of the images - it is in X9 but must be possible to find the location for later versions as well - and how to make and use them - I would think you could copy the image you are using going the wrong way and use an image manipulation programme (Photoshop , Paintshop , Photo plus etc.) to flip it left to right and then put it back into Videostudio for use .
The previous discussion is here - - viewtopic.php?f=1&t=60420&p=333575&
just back checked and all the clip art used by Rotopen - even in 2018 are stored in sub folders here : - C:\Program Files\proDAD\HeroglyphRoute-4.0\clipart\
mwsing
ram: 6 gigabyte
Re: Rotopen
Post by mwsing »
Thanks. I can already get the standard picture of the car or plane or whatever. In October 2018 when I last tried this there was a way of clicking on the car and the same car pointing in different directions appeared. This does not seem to happen now. I can only get the car pointing horizontally to the left, which looks a bit silly if I am following a route going south! I may have implemented an update to the 2018 software but have not installed 2019. I do'nt see how knowing the location of the files helps me, although I have located them where you said they were.
BJC
Re: Rotopen
Post by BJC »
knowing the location of the files helps you to copy the image of the car - flip it in an external programme and then put the flipped image back into the folder and then add it to your project
for instance - car going one way
car going the other way
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Re: Rotopen
Post by tletter »
mwsing wrote:How do I make the symbol in Rotopen point in the direction of travel.
Use the Retrace Route option.
tletter
mwsing
ram: 6 gigabyte
Re: Rotopen
Post by mwsing »
Thanks for this - but how is it I could do it within the program until just now?
