VS2019 SP3 Released today 17 May 2019
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Here is the list of supposed fixes since SP2 was released
Pan and Zoom adds an extra keyframe
Photo is inverted in Library
VS Crash when in Pan and Zoom, Copy and Paste attributes
Split audio and trim, clip still plays to end
Second instance of same clip added to TL, will add before the first one
Can't move group on timeline
Library->Path category loses newly created folder
Ripple edit fails in TL mode, but not Storyboard (from Beta)
UI overlap in MCE, in Japanese
Cannot import Slow Motion files from Samsung Galaxy Note 9
Export MTS as M2T, green artifacts in exported file
iPhone MOV previews all white
[Mask Creator]Text Mask will display garbage characters, in CT
Incorrect insert position while adding Instant project to Timeline
MPEG4 downsize rendering will be black and white with artifacts
Add CS support in MCC Lite
"Complete" category is missing from Instant Projects
MCC Lite shouldn't add .xml file to VS library
Can't capture again, after first capture is complete
Drone camera MOV improperly displays added filters
Patch progress bar is hidden by "please wait" dialog
Change video tutorial link in CS
BCC effect is missing, when preview in title Library
Change link to Video Tutorials in CS (other links)
Transition disappears, or UI artifacts, when a graphic coexists with transition
Customize Motion fails, if path has been applied for a clip
Freeze Frame in new project, VS crashes
Insert as 360, can only edit first frame
Select video and audio, then right click insert to any track, VS crashes
Voice-over unresponsive after adding filter to a clip
In Storyboard, move a transition, VS crashes
Error message from Track Manager
Set AVCHD export to 1440, exports as 1920
After import, clips already on timeline will be black
Clips cannot be selected after nudge [Alt+→ or Alt+←]
VS crashes when apply crop effect to a clip, then "Add current effect to My Favorites"
Morph Transition previews badly if inserted between photo and video
JWolters
motherboard: MSI Z170A GAMING PRO CARBON
processor: Intel Core i7-9700K
ram: 32GB-3200
Video Card: NVidia GTX 1060-6GB
sound_card: Lumix FZ2000 and GH5 and BMPCC4K
Hard_Drive_Capacity: 20TB-SS+HD
Monitor/Display Make & Model: 2x ASUS UHD
Corel programs: PS 24U, VS 2020, 3rd party
Re: VS2019 SP3 Released today 17 May 2019
Post by JWolters »
Hi.
Wow, always the folk of Australia. They celebrate not only "New Year" before us, they also get the VS updates sooner. :x :D
Regards Hansi
my independent website
The new version number I get is 22.3.0.433...
pepegota
motherboard: ASUS TUF Z390-Plus
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Ben Q, "21" LCD
Corel programs: VS 2018, VS 2019, VS 2020
Post by pepegota »
Same here. In addition, the method of update was improved as one could see the download% in the upper right side of the program-no more waiting and guessing.
pepegota
ram: 64 GB
Post by pepegota »
I had to do a reinstall and I have version: 22.3.0.436
cdoughertycd
motherboard: ASUS PHTD DELUXE
processor: 4 Core 2-93 gigahertz Intel Xeon
ram: 36 GB
Video Card: AMD Radeon HD 7700 Series
sound_card: AMD HD Audio
Monitor/Display Make & Model: Samsung S24B300
Corel programs: many back to VS 5, all up to 2022 Ult
Post by cdoughertycd »
Hi, probably dumb question, but where do I find VS2019 SP3? Can't seem to find it when I google it.
Thanks,
Candy
RobertOZ
Post by RobertOZ »
Go to Help, make sure that Check for Updates is set to Auto-Check for Updates Daily, then when you start VS you will be asked if you want to download any available updates
