I have text scrolling up on a photo background. I didn't do the whole Star Wars thing, just text going straight up. Problem: when I play the clip, the background shows up but the text delays for about 5 seconds before it begins to show up and begin its crawl. Is there a way to make the text appear sooner on the background, or to make it begin its journey from the middle of the background picture?
I tried clipping a few seconds from the text part on the timeline, but that just made it go faster.
Bill
Scroll text
gewb
- motherboard: MSI Pro B550-VC
- processor: AMD Ryzen 7 5700X
- Video Card: ASRock Radeon RX 6650 XT
- Monitor/Display Make & Model: LG 24MK430
- Corel programs: 2018, 2021, 2023 Ult.
Re: Scroll text
Move the top of the text box farther up and begin the first line of text at the top of the text box.
BJC
- Hard_Drive_Capacity: 1TB
- Corel programs: Videostudio X10 and 2020
Re: Scroll text
How did you make your scrolling text title - did you use one of the preset ones or did you make it from scratch using one of the other methods like "Customise Motion"
either way it's just a setting change
*IF* you used the preset title then first double click on the text box in the timeline to open the options panel - click on the 'Attribute' tab in the very top right corner should now see this
note the double 'T' icon which I have circled - click on it and you should see this
now click on the button in the centre of the left hand set - these two blocks set entry and exit modes for the text block
click OK and return to editing - when you play the title sequence your text should now start in the middle and scroll up
If you used a different method to produce your scroll - or if that does not do what you want then we can use alternatives
Shepdog1
- System_Drive: D
- Corel programs: VIDEO STUDIO
Re: Scroll text
Thanks to both replies! Worked great.
