VideoStudio Ultimate 2019 KEEPS AUTO SHUT DOWN
mwsing
- motherboard: Dell Inc 0C2KJT A00
- processor: 2.93 Gigahertz Intel Core i3 530
- ram: 6 gigabyte
- Video Card: NVIDIA GeForce310
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: Viewsonic VX2240W
Re: VideoStudio Ultimate 2019 KEEPS AUTO SHUT DOWN
I have not replied for so long, because I became completely frustrated. Core'ls latest soluton was to do a Clean up to delete Version 2019 and re-install the software (again). I have done this but the problems persists. Having just bought Version 2019 in December, I am loathe to buy Version 2020 which may well have the same proble. I have reopened my ticket with Corel but am not hopeful of a solution, gien my history on this one!
OKIEWARDOYO
- motherboard: Foxconn G31MXP Socket 775
- processor: Intel Pentium Dual Core E5400 2.70GHz
- ram: 2GB DDR2
- Video Card: SMB1630N 1280x768 60Hz Intel G33 G31 Express Chi
- sound_card: onboard
- Hard_Drive_Capacity: 320gb
- Monitor/Display Make & Model: samsung
Me too.
I have drag and drop a 3minutes mp3 file to timeline.
it i change duration of this mp3 file, and play, my corel video studio crash and shotdown immediately.
- stevef
- motherboard: Z2MiniG4
- processor: Intel Xeon E-2174G at4GHz
- Video Card: Radeon Pro WX 4150
- Hard_Drive_Capacity: 10tb
- Monitor/Display Make & Model: Visio Television
- Corel programs: All Videostudio Ulead to Corel VS2021
This is likely due to an incompatible project size or setting. If your project is set to 1920x1080 and you try to import a video file that is not that size, often the application will just crash. This is the case with some images too. Everything must be sized to the working project file to ensure the best editing. This is not how it was in previous versions. Now, all older files that are being imported into VSUlt are opened on another workstation running VS9 and exported with similar output settings to the target project. On crash there is no easy way to determine the error report being generated. This solution was found through trial and error.
mwsing
- ram: 6 gigabyte
Thanks. I'll check this when I have time. At the moment I have given up for a while, because I have got so frustrated.
mwsing
- ram: 6 gigabyte
My saga continues. After many, many suggestions from Corel, none of which soled the problem, I decided to download a trial version of Videostudio2020. This appeared to work for a while while editing. The only problem was that the latest version does not recognise my .MOV clips that I imported from my iPhone. I had to carry our another step and convert them to mp4 files. This is a decrease in functionality from all previous versions. However, I mostly managed to finish editing the proect with only the occassional crash. Yesterday I tried to look at it with my wife and it crashed every other minute! I am despairing! It seems nothing will fix it. I certainly wont be buying Videostudio 2020.
- stevef
It is likely that your .mov file may be of a different project size. Just check your phone video settings and make sure they match your project settings. Transferring to mp4 does waste time. And this program, with the constant crashes (lazy programmers), eats up so much production time it's hard to stay within quotes. A 5 hr editing session is eaten up by dealing with these types of issues. So I feel for ya. By any chance, when you reopened the file, did you move it to another directory or is any of the source material (ie filters, mask, sound) on a network computer that is not connected? The relinking feature has become a nightmare and is so flawed. Even creating a project file is useless because it leaves out core elements so the package is incomplete, which causes constant crashing on reopen... all the best
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Do you have the required codec installed? If not then install it.mwsing wrote:The only problem was that the latest version does not recognise my .MOV clips that I imported from my iPhone.
VS struggles with variable frame rate video which undoubtedly these iPhone video use. VFR videos will require conversion to a fixed frame rate format before adding them to a VS project.
tletter
