Flipping image when capturing video, VS9
Doc35
Post by Doc35 »
I'm new user, and knowing the new program, I used to use the VS8, without probs, first problem was no audio in imported DVD's from my Handycam, Dolby Digital sound, the problem was solved upgrading to VS9, but the main problem is that I need to capture video from a microcamera attached to an endoscope, and the image flips upside down when capturing, and I cannot perform the Endoscopy studio!, the image is placed OK when finished, but in the time of capture I can't see it well, have you any hint on this prob? :cry: :?:
Post by Trevor Andrew »
Try FXbench from the Burger site. This is a video filter and can flip the video file.
I have not used this filter therefor cannot comment on its performance.
But if its as good as the transitions it will be ok.
http://www.burgers-transition-site.de/d ... index.html
Doc35
Post by Doc35 »
Is not in the transitions, is in the live capture video, during the capture, maybe it'll work I'll try, hope it works, the camera is working OK in other software, Pinnacle, but this has a very little preview window, and that's the reason not to use it! thanks for the answer! :), does anybody has another hint?
trevor andrew wrote:Try FXbench from the Burger site. This is a video filter and can flip the video file.
will flip video in timeline after capture
Doc35
Post by Doc35 »
The problem is not after the capture, is during the capture, after the capture the clip is saved upright, but during the capture the video is upside down and I need it upright because is an endoscopy in real time I have to review it! and drive the endoscope through the upper GI tract! :)
I have a Geoforce4 Graphics card. It includes software that enables the image on the monitor to be rotated 90 / 180 or 270 degrees.
If you have the same/similar graphics card you could perhaps try/get by with that.
(Duplicate post deleted - machine froze up)
THoff
Post by THoff »
There are numerous possible causes, from bad codecs to bad video drivers. It is NOT a Videostudio problem.
The first thing I'd go is update the video card drivers to the latest WHQL-certified version that is available, remove any codec packs you might have installed, and run Windows Update to download any update (especially for DirectX) that might be available.
Doc35
Post by Doc35 »
maybe thats the prob because it was working ok, or ill reset the computer to a reestore point before the time it started the problem?
Doc35
Post by Doc35 »
The problem is solved!, I installed the VS9, and ok, see ya!
