Given up on 2019
DH88Comet
motherboard: Gigabyte Z270X Ultra Gaming
processor: i7 7700 3 point 6GHz
ram: 32GB
Video Card: NVIDIA GEFORCE GTX 1060GTX
sound_card: ONBOARD 6 CHANNEL
Hard_Drive_Capacity: 19TB
Monitor/Display Make & Model: Iiyama ProLite B2792HSUB1 27inch & Dell S2009W
Corel programs: VideoStudio X8, X9 X10 2018, 2019 & 2021
Given up on 2019
Post by DH88Comet »
That's it. I give up, 2019 is unusable. It is unstable - crashes with no provocation although not as often as it did at first. But the straw that broke the camel's back is the fact that Mercalli 4.0 completely screws up all transitions. As I film entirely handheld I always apply Mercalli to each clip, no problem using X8, X9, X10 or 2018, but not 2019. Apply Mercalli and add a transition and it asks for the analysis to be run on the transition. I have heard it said that this is because the clips either side of the transition were different frame rates or resolution. If I have that, it works, but two clips from the same camera done at the same time fails.
So now I have removed all Mercalli filters and saved as version 2018, and applied Mercalli v2.0 in 2018 and all's fine. So I'm now stuck using 2018 after having paid for this 'wonderful' new upgrade.
pepegota
motherboard: ASUS TUF Z390-Plus
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Ben Q, "21" LCD
Corel programs: VS 2018, VS 2019, VS 2020
Re: Given up on 2019
Post by pepegota »
No problems with stability here. If you are not using the update that's why you are having these problems which, were present on the initial release. Mercalli works fine if you know its idiosyrcrasies.
