Creating new selections
RavenSHO
Corel programs: Had X, 14, now 2019
Post by RavenSHO »
Ive had multiple versions of this program over the past decade, but now that I have a new computer I was forced to buy the 2019 version, as the last version I had was PSP14. My issue is now, I can't cut and/or copy a selection from one item to put into another. It is always grayed out, unless I use the original item only. Any help on this would be great. Yes, I have it in edit mode, layers are up, as I have done so with all previous versions of this program.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Creating new selections
Post by Jean-Luc »
RavenSHO wrote:It is always grayed out,
What is greyed ?
I draw a selection.
I make Edit / Copy
I activate another image.
I draw a selection in the target image.
I make Edit / Paste into Selection
The selection is copied inside the selection of the target image.
It works as expected on my PSP 2019.
ehume
processor: i7 4770k
sound_card: no_sound_card
Post by ehume »
PSP14 = PSPx4. Things may have changed (I'll look later). Ctrl-V no longer means 'paste,' as it does in Windows-compliant apps and as it did in PSP7. Now You must right-click and choose from the various Pastes in your context menu (there are multiple context menus; you can customize each one) or Edit > various pastes. Alternately, use Ctrl-Shift-V, Shift-Insert or Ctrl-e (= Paste as New Selection).
Edit1: I looked at PSPx4 (= PSP14). The Paste options are the same as PSP20 (= PSP 2018). Can't say what the problem is.
Edit2: I looked at PSP 4,5,6,7,8,9,10,11, x4, x10 (PSP 2018). The sole option for paste as a new image was ctrl-V through PSP8. In PSP9, Shift-Insert was added to Paste as a new image. This was still present for PSP11. By PSPx4 (PSP14), Paste as a new image was Ctrl-shift-V and Shift-Insert. No more mere Ctrl-V.
RavenSHO
Post by RavenSHO »
Jean-luc... grayed are the options to paste of new layer, new selection.. I can paste as new image but kinda defeats the purpose.
Ehume... tracking... normal do ctrl-e for new selection but that does not work. I right click it only allows for new image.. if I go to the edit tab on the menu, it only allows for new image...
Jean-Luc
Post by Jean-Luc »
RavenSHO wrote:Jean-luc... grayed are the options to paste of new layer, new selection.. I can paste as new image but kinda defeats the purpose.
What are your exact steps ?
Did you try the exact steps I listed ?
Or do you work differently ?
I seems to me some info from you is missing. It may be a detail... :)
