Hello,
I would like to stabilize a time lapse video, but I have the following strange effect between 8 and 11 secs.
I tried with both of Mercalli v4 (using as default and usually it is working well) and the built in Anti-Shake effect but all of are producing the similar result.
I admit that it is a challenge to stabilize well a timelapse like this where everything is moving, but I am looking for any solution.
I also tried to split into 3 parts the video and ignore the middle (and only stabilizing the beginning and the end separately), but it is a nightmare to find the proper zoom/scaling to join them again.
The Anti-Shake effect supports key frames but it is not working for some reason, whenever I modify one key frame the modified value is applied for all...
The video link is:
https://1drv.ms/v/s!AurQqvuWbSARlftyYWjR6JFijTOjFA
Do you have any suggestion to solve it?
Warp stabilizer strange behavior on timelapse video
iNate
- motherboard: ASUS GL503VD
- processor: Intel i7-7700HQ
- ram: 32GB
- Video Card: Nvidia GTX 10xx
- sound_card: Realtek
- Hard_Drive_Capacity: 250+512GB
- Monitor/Display Make & Model: ASUS 15.6" + HP 24" 1080p IPS Displays
- Corel programs: PSPX9, VSX9 Pro, VS2018 (Refund), WPOX7
Re: Warp stabilizer strange behavior on timelapse video
Have you tried rendering out the time lapse, and then stabilizing that video?
Yes, I tried on:
- The original video (GoPro6 Timelapse video)
- Exported in h264 format
- Exported in h265 format
All of them have the same results.
iNate
- ram: 32GB
I meant you create the timelapse, without stabilization.
Then, you render out that video.
Then you reimport that video into a new project and apply stabilization to it and re-render it with the stabilization on.
That way, you aren't doing Time Remapping and Stabilization on the same source footage.1
