Play back starting again
zehavi
processor: Intel[R] Core[TM] i7-8700 CPU 3.20 GHz
Hard_Drive_Capacity: 465 GB
Monitor/Display Make & Model: LG
Post by zehavi »
Hello,
When playing back on TV a mp4 movie from a disk-on-key, after the end of the movie it starts to play again from the beginning.
Is there any way to eliminate it?
Thanks,
Abraham
Re: Play back starting again
Abraham
I assume you have burnt a DVD disc, although you mention MP4??
and i am not sure what you mean by disc-on-key, but if it is a DVD Disc then....
Share – Disc – DVD opens the burner module
To the bottom left are several icons, the cogwheel (Project Settings) has a setting for Navigation Controls
By default set to “Auto Repeat when disc playback ends”
Deselect that to set “Continue to play next clip” or “Back to Menu”
These only affect the Titles and not the Chapter points
1 / “Continue to play next clip” will play the complete disc to the end then return to menu
2 / “Back to Menu” will play the selected Title then return to Menu to allow another Title to be selected / played
For your existing disc I am afraid there is nothing to be done and the disc will have to be burnt again.
Some info on Navigation here-- Title or Chapters menus explained.......
http://lata.me.uk/corel/all.htm
Hope this helps
zehavi
Post by zehavi »
Thank you Trevor,
Disk on key is a small disk with USB connection. It could also be connected directly to a smart TV.
Obviously, it's possible to store any kind of files in this disk.
Attached is a photo of this disk.
Regards, Abraham
disk on key.png (9.17 KiB) Viewed 1167 times
canuck
operating_system: Windows 8.1
Post by canuck »
zehavi wrote:Hello,
Thanks,
Abraham
Disable the "replay" or "loop" function on your TV
