Rectangle tool malfunction?
ehume
processor: i7 4770k
sound_card: no_sound_card
Post by ehume »
I went to create a rectangle using the Rectangle tool in PSP 2018. It came out an ellipse. I ctrl-z'd it. Saved the image, closed PSP, reopened, and it did the same thing. Changing to the Ellipse tool did not produce a rectangle; and when I changed it back to rectangle it was still an ellipse.
I again saved the image and reopened it in PSPx9. This time I was able to produce a rectangle, so I used that.
Anyone else see this issue? Or do I need to reinstall PSP 2018?
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Shape tool malfunction?
Post by hartpaul »
There is also a rectangle choice in the Preset Shapes tool does that work?
ehume
processor: i7 4770k
Post by ehume »
hartpaul wrote:There is also a rectangle choice in the Preset Shapes tool does that work?
The Presets window is empty.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Not Presets. Preset Shapes tool on the toolbar to the left of the workspace.
But I have no idea why you can't get the Rectangle tool to be a rectangle in PSP 2018 as long as you also have that selected in the Selection Type in the Tool Options ribbon.
However, you made your post even more confusing by making the subject "Shape Tool Malfunction". Were you using the Preset Shapes tool, or the Rectangle tool? I have never before heard anyone calling the Rectangle tool the Shape tool. But you said in the body of your post that you were using the Rectangle tool. :?
Preset Shapes tool
Preset Shapes tool
JoeB
Using PSP 2019 64bit
ehume
processor: i7 4770k
Post by ehume »
Thank you. I have changed the title of the thread.
How odd. I have followed the Help directions and reset the database. The Rectangle tool still makes ellipses.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Rectangle tool malfunction?
Post by LeviFiction »
On the tool options palette, set radius x and y to zero.
ehume
processor: i7 4770k
Post by ehume »
LeviFiction wrote:On the tool options palette, set radius x and y to zero.
Thank you. That solved the problem. Now that you have pointed this out, I recall changing the corner radii when I was horsing around. Thanks again.
hartpaul
ram: 8 Gb
Post by hartpaul »
And once again the advice is valid - if a tool is malfunctioning go to the Presets up the top and click the Reset to Default button and that would have fixed it.
ehume
processor: i7 4770k
Post by ehume »
hartpaul wrote:And once again the advice is valid - if a tool is malfunctioning go to the Presets up the top and click the Reset to Default button and that would have fixed it.
Good advice . . . if someone has heard it before.
Also, the reset button is hidden inside the Presets window, which of course is empty by default. And the Reset button is unlabeled -- only by hovering over it does the label appear.
So, thank you for reiterating this good advice.
