Remove Paintshop Pro 2018 from Win 10 Startup
Slainte
Corel programs: paontshop Pro 2018
Post by Slainte »
PSP 2018 runs when I startup my computer. It does not show up in the START menu, so I cannot disable it. However, all monitors of my system show it running. I do nt use the management function, so it is not cataloging pictures.
Does PSP have a setting that prevents if from running at startup? Or conversely, settings that can be turned off to prevent it from running? I want it to run on demand only.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Remove Paintshop Pro 2018 from Win 10 Startup
Post by JoeB »
It might be stuck as a background process. In Windows 8.1 I would open Task Manager and if you see a Corel PSP process running then right click it and click End Task to try to remove it. I don't know what the equivalent is in WIN 10.
JoeB
Using PSP 2019 64bit
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
It's the same in Win 10. JoeB.
But a stuck process shouldn't restart with the computer unless the restart apps flag was included with the call.
Slainte, you say all monitors show it running. So I'm assuming you don't actually see PSP startup with a splashscreen. Can you take a screenshot of the process monitor where you see PSP?
You could check your startup folder. But I doubt it would be there.
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp
ehume
processor: i7 4770k
sound_card: no_sound_card
Post by ehume »
In Win 10, right-click at the bottom, on the Taskbar. The context menu has Task Manager 3d from the bottom. In the Task Manager, you have a 3-item menu bar, then below it a tab bar. The startup tab is 4th from the left. You may find PSP there.
