Thank you!!!
Oh, and PS How do I update my profile?
Ripple editing only applies if you have enabled it on a particular track after enabling it on the video track. In fact, you may find that you don't want to enable ripple editing on all tracks.JimDodds wrote: 1. The KEY to Ripple Editing is that
2. ANY change you make is applied to everything
3. AFTER the
4. END of the clip you’re changing
Click on the User Control Panel at the upper left of the window.JimDodds wrote:I still don't know how to update my profile
BJC wrote:Ripple editing locks all other tracks to the top timeline - it will not work if you are adding clips to an overlay or title track - if you want to add something at the beginning try just putting a plain color block at the start in the top track and setting that to the length you require - doing that *should* move all locked tracked as one - then you can add your titles etc. in the appropriate track at the beginning
