Videostudio 2019 Service Pack Now Available
imaref
- motherboard: HP 8BA9
- processor: Intel Core i7-13620H
- ram: 64GB
- Video Card: Nvidia RTX 4050 and Intel UHD
- sound_card: Realtek
- Hard_Drive_Capacity: 1TB SSD
I just launched VS2019 and clicked on "check for updates". It says there is an update available and it's currently downloading in the background.
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
Re: Videostudio 2019 Service Pack Now Available
Following the update, I'm now running VS 2019 22.2.0.396. However, it's not clear what this update fixes as there is no readme file that I can find listing bug fixes. It almost seems like VS is a one developer effort and so there is no time to document any changes.
tletter
tletter
- glus
- motherboard: MSI Z390
- processor: Intel i9-9900K
- Video Card: NVIDIA GeForce 2060
- Monitor/Display Make & Model: Acer X233H
- Corel programs: VideoStudio, Pinnacle Studio
Here is a list of bugs fixed in VS 2019 Service Pack 2:
Inserted transition goes to wrong place, hides clip, and creates gap
Several bugs working with transitions
Fixed some Translation errors
Regression: Library UI problem when switch from Share to Edit
Mask creator - errors in mask duration
Regression: "Split Clip", "Split Audio" are missing from VS 2019 clip context menu
Removing VS 2019 will disable 3D Titler in 2018 and vice-versa
Customize Motion: Shadow and Border don't respect Alpha Channel
Move grouped photos, VS crashes
Customize Motion has missing or incorrect preview
Insert video to front of timeline, is difficult in main video track
Frame Frequency not working in clip speed
Regression: Track rename isn't saved
Crash when add clip to storyboard
Show stop sign when trying to insert clip in front
"Corrupted video file cannot be dropped" when move a clip to close an unwanted gap
Clip missing, wrongly ordered, preview of wrong clip after Story-TL switch
After Alt-Tab, can no longer select clips on TL
Clip on timeline cannot be selected
Crash when Morph transition between photos, click Customize
Color depth in clip properties displays wrong values
VS will crash when open / preview MCC created project
Mask Creator: Text mask - text or move buttons, cause mask to vanish
Transition "My Favorites" folder becomes empty after updating
Graffiti templates included in VS 2019 Instant Project library
Mask Creator: Add text mask, OK button will be gray - can't add to timeline
Remove Gap dialog needs "don't show again" checkbox
Mask Creator: manual entry of font size, rotation values fails
Move clip from Video to Overlay, then back - overlay UI is still present (also 2018, but not X10)
Tooltips in the preview window panel are missing
VS Lens Correction: edits to UI text, option to save custom preset
VS not retain Visual Layout Settings on Close
3D Title does not preview on Title track, works fine on Overlay track
Crash on startup after changing default start screen
Can't add keyframes without changing settings
Clip in project has black preview
Digital Camera compatibility updates
Time Remapping changes are not shown on timeline
Add to Overlay or Title tracks, can delete but not move
Thumbnails corrupted in some MOV files
Regression: MCE displays only one stream, others blank
Morph: Portrait will be stretched in preview
Title, "Insert To" - error "Encountered an improper argument."
MCE: play one source, all other sources will show the same view
Must restart VS to see update notification
Iphone HEVC 4K previews black
Removed items from tool bar will return after VS is restarted
360 Keyframe values are incorrect after applying Speed
Project Properties - Reset, dialog has a typo
Can't import LUT profiles
- Granpaw Broon
- motherboard: Asus Prime Z490-A Pro
- processor: Intel i9 10900K 3_7GHZ
- ram: 64GB
- Video Card: NVidia 1050Ti Intel UHD Graphics 630
- sound_card: RealTek HD Nvidia HD
- Hard_Drive_Capacity: 12TB +2GB SSD
- Monitor/Display Make & Model: LG Flatron W2452TX
- Corel programs: VStudio X7,X8,X9.5,X10.5,2018,2019,2021
Glus, is there any reason why Dolby Digital Surround Sound has been removed from VS2019 Ultimate but is present in previous versions. If this is on purpose then I shall have to go back to VS2018 as this is a feature I use frequently. I wrote to Corel last week on this but still have not had a reply.
- Davidk
- ram: 16Gb
- Hard_Drive_Capacity: 6Tb
The ac3 dolby codec in 2019 is a topic I have ranted on, elsewhere, with Corel.
Simply put, Corel decided (yes, a deliberate decision) that the AC3 codec (dolby sound) would only be supported in 2019 if you ran VS on windows 8 or windows 10. your post is the 1st i have seen reporting that dolby doesn't work with 2019 under win 10. For me, running windows 7, that decision made my archive of video clips recorded with dolby sound (around 172Gb) as just a box of silent movies if used with 2019. I wasn't happy about that.
That Corel did this makes no sense for a windows based product, in that
- the dolby patents have all expired (the last one ran out in March 2017), so there is no licence fee payable to use the codec
- windows 7 is the equal largest, or 2nd largest (depends on which stats counter service you use), windows market world-wide, in Feb 2019. In comparison, vista has vanished from the stats, windows 8 is barely larger than Xp3 (around 5% each) whereas win 10 and win7 are both at about 38-40%
- the codec must be in the download, as the only way the installer can determine the OS in use is at install time.
I did suggest that Corel include the AC3 codec as a paid extra for win 7 users if it was of such desperate importance to them, but that got ignored too.
So, immediate and longer term, the only option when using clips with dolby sound is to use an older version of VS. Don't throw it away - different versions of VS can be installed on the same computer - but only one will run at a time. If you run win 7 and VS2019 is your first experience with Video Studio, and your archive is with dolby sound, then get a refund. The earlier versions of VS that do support dolby are not available now, unless you can find a disk version somewhere.
tletter
X9 and X10 which both support Dolby Digital 5.1 are still available on Amazon, e.g. https://www.amazon.ca/Corel-VSPRX9MLMBA ... way&sr=8-1, and perhaps other non-pirate sites.Davidk wrote:The earlier versions of VS that do support dolby are not available now
I have all versions of VS since X4 installed and see no reason to uninstall any version since they seem to co-exist and disk space is cheap.Davidk wrote:different versions of VS can be installed on the same computer
tletter
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Not strictly true now, many users have conflict problems between VS2018 and VS2019, which whilst Corel are aware of the issues, not much appears to have been done to correct them.tletter wrote:
tletter
There are different issues depending on your OS, Win 7/Win10. If you have VS2018 installed, then install VS2019, you need to carefully check VS2018 and look for any changes, you may find some items have disappeared
- Granpaw Broon
- ram: 64GB
I have VSX9.5, X10.5, 2018, 2019 and Pinnacle 22 all Ultimate versions installed on my PC and they all work fine except VS2019 which is the only one that doesn't support Dolby Digital any more. In my opinion X10.5 is the most reliable even though it doesn't have the later features.
svenmansson
- motherboard: HP 2B47 1.04
- processor: Intel I7-6700 3.4Ghz
- Video Card: NVIDIA GeForce GTX 970
- Hard_Drive_Capacity: 1.5TB
- Corel programs: Corel Video Studio 2019, 2018, X10
How can I find VS 2019 Service Packs? I check for updates but "There are no updates available at this time". When I download/install there is no service pack. HELP me.
imaref
- ram: 64GB
Depending on when you bought it, you may already have the current version. Go to HELP, and then ABOUT - you should be on version 22.2.0.396
Imaref is correct that all new / recent purchases will include the service pack as part of the program,
therefor no additional updates will be required. At least that's my experience
Afaik that will be the same when reinstalling the program, the web installer will download the main program (Ultimate / Pro Folder) prior to installation.
To make sure I had the current up to date files I chose to download and re-installed the program as new after SP2 release.
Kingston
- motherboard: Gateway [Acer] DX4860
- processor: Intel Core i5 3rd gen. 3 GHz
- ram: 8 GB
- Video Card: Intel HD 2500
- sound_card: Bluetooth
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Supposedly SP2 fixed problem with Lens Correction not having a Save Custom preset button. Now that I have installed SP3, I still don't see a way to name and save a custom preset. Every clip on the timeline has to have the intrinsic parameters set up from scratch -- and that's ridiculous.
