Hello folks.
I am trying to sync 2 Video sources and 1 Audio source by audio (looking at the wave form and putting down a marker).
One Audio from one camera is very low volume (but enough to hear, is volume is increased), so usually sufficient to sync, if in the Multi Camera Editor I could somehow manage to increase the wave hight (volume) by faxtor x.
The way it currently is, it is pretty much impossible to perform a proper sync. Any suggestions?
VS2018 Multi Camera Audio Sync Question
WorstCases
- System_Drive: S
Re: VS2018 Multi Camera Audio Sync Question
You can zoom into the timelines that will stretch horizontally, max is to view each frame one at a time.
Zoom slider lower left, press the "+"
By nudging the digital clock you can accurately set the play / position cursor, then hit the “Set / Remove Marker” for each camera angle and audio files.
The markers can only be set to full frames
Hit the “sync” icon and things should jump into place.
WorstCases
- System_Drive: S
Thank you lata.
I got it wo work. My issue is the very low volume on one camera - therefor I can hardly see any audio wave to perform a sync that way. I was hoping there is a way to "increase volume", so that I can see the wave enlarged for sync purposes...
You can also set the Markin points by viewing the video frames instead of the audio stream
Good that you managed to sync the clips.
