Hi Everyone!
I'm looking solution for a long-standing problem. I have a lot of brushes. Approx. 1000 pcs./folder.
When I want to choose one, I have to wait a minute for the drop down window. So annoying.
Is this the weakness of the program or should I do some hardware development?
See the performance of my machine here---->
I've been trying to put fewer brushes in folders, about. 500-700, but the drop down window that opens is still very slow.
Thanks for the tips.
Brush drop down window opens very slow
azakihun
- processor: Intel Core8TM i5-4440 CPU 3.10GHz
- Video Card: Intel HD Graphics 4600
- sound_card: Realtech High Definition Audio
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: DELL Ultrasharp
- Corel programs: PSPX9
fecnikek.blogspot.com
- hartpaul
- ram: 8 Gb
Re: Brush drop down window opens very slow
You are heading the right way, but try going further try reducing the brushes in your folders to the bare minimum that comes with PSP and see what the timing is there.
If it is greatly improved then you will know where your problem lays. Then start adding your must have brushes a small group at a time and check and time how long and when the delay becomes problematic you will learn your/ the programs limit.
1000 brushes ? Even if you use your program every day that would mean three different brushes per day. Perhaps time to declutter.
- ehume
- motherboard: Gigabyte GA-Z87X-UD4H
- processor: i7 4770k
- Video Card: Intel HD4600 [iGPU]
- sound_card: no_sound_card
- Hard_Drive_Capacity: 512GB+4TB
- Monitor/Display Make & Model: Acer KN242HYL
- Corel programs: PSP 2018 32b & 64b, AS3 64b, PE5 64b
Grand advice, but I might suggest asking a Corel coder if having so many brushes slows down a menu. OP - One thing you might try is to collect all your brushes in one folder without subfolders. Then with Preferences > File Locations... delete the lookin directories you currently use and replace with the all-in-one folder. Now, see how fast the menu drops down. Faster? Slower? You tell us.hartpaul wrote:You are heading the right way, but try going further try reducing the brushes in your folders to the bare minimum that comes with PSP and see what the timing is there.
1000 brushes? Even if you use your program every day that would mean three different brushes per day. Perhaps time to declutter.
