Hello,
I have a video shot titled about 20 degree. It there any way to get it straighten out like using the straighten tool in Paint Shop ? Thanks for any tips, tricks and idea .
Any straighten tool or filter for video
BJC
- Hard_Drive_Capacity: 1TB
- Corel programs: Videostudio X10 and 2020
Re: Any straighten tool or filter for video
If you use "Customise Motion" you can rotate your video one degree at a time - while in the customise motion window you can also zoom in a little as rotating a video may cause the edges of the video to move inscreen a little
by default the customisation effect changes throughout the length of the video so check you set the same settings at the key points at each end of the video to make sure they are the same
To set keyframes to same, right click the keyframe for options, "copy and paste to all"
Some filters using Keyframes do not support that but Ctrl + C and Ctrl + V should copy from keyframe to keyframe, a little quicker that tweaking all the settings.
okyou
- Video Card: onboard
- sound_card: onboard
- Hard_Drive_Capacity: 2TB
- Corel programs: X9 Ultimate
It works. Thanks very much for both idea.
okyou
Hello,
I still has a question for you. After I used the custom motion to rotate the video to the right level and max the screen, how can you get rid of the black area on both sides as attached pic ? I tried to played with the crop border filter but it don't seem to work. Thanks for your help.
weaver
- processor: intel i7
- Video Card: nvidia Ge Force GF 550 Ti
- sound_card: C.Media
- Hard_Drive_Capacity: 20TB
- Monitor/Display Make & Model: FULL HD
- Corel programs: VS S6,8,10 on W XP, VS X4,6,7,2018
You have to zoom the picture to the size of the screen. ( extra FX)
Using Customise motionBJC wrote:If you use "Customise Motion" you can rotate your video one degree at a time - while in the customise motion window you can also zoom in a little as rotating a video may cause the edges of the video to move inscreen a little
1 / set rotation “y” to desired amount
2 / set "Size" above 100 to Zoom-In
3 / set first and last keyframes to use the same settings.
okyou
Hello lata,
It work. Thanks very much for your tips.
