Printer issue
joel_l
Printer issue
Post by joel_l »
I have an HP Office Jet Pro 7740, latest drivers. Whenever I try to print from PSP 2019 I get an error " Tab control failed to initialize" a mangled print dialog appears followed by a crash.
Sometimes I can print one page but the second will always crash.
This same issue existed in 2018
Any thoughts?
Joel
bruce1951
operating_system: Windows 8.1
ram: 8gb
Re: Printer issue
Post by bruce1951 »
I can't give you a specific answer. But I would suggest that if you wish to print more than just 'basic' images and work then I would suggest a dedicated program such as QImage.
http://www.ddisoftware.com/qimage-u/
bruce
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Printer issue
Post by Jean-Luc »
joel_l wrote:. Whenever I try to print from PSP 2019 I get an error
Are you using Print or Print layout ? Try both and see if it helps...
Is your printer connected bi Wi-Fi or USB cable ? Try both...
joel_l
Re: Printer issue
Post by joel_l »
I have been using the print command, I will try the print layout.
I am connect via LAN, no other option.
Update: I tried print layout and have the same result, seems if I try to open setting or properties a second time PSP crashes. Seems this issue is persistent for several revs of PSP.
JoeB
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Printer issue
Post by JoeB »
Unfortunately most of the topics I recall reading over the past couple of years at least about printer issues usually involve HP printers. I can only suspect that there is something about at least some HP printer driver software that PSP sometimes chokes on.
JoeB
Using PSP 2019 64bit
joel_l
Re: Printer issue
Post by joel_l »
I recently installed CorelDraw and tried printing from Photo-Paint, it works just fine. So seems there is a solution, Corel just needs to want to fix it.
