Has anyone run across Droste effects for Paint Shop Pro-
either filters, scripts or tutorials?
I've seen them for other programs, but nothing for PSP
(using versions PSP X7 up through PSP 2018)
Thanks in advance!!
Paul
Searching for Droste Effects
- PekyleCA
- motherboard: gIGABYTE
- processor: i7 8th gen
- Video Card: GeForce GTX 1050Ti
- sound_card: built-in
- Hard_Drive_Capacity: 3.5TB
- Monitor/Display Make & Model: Gigabyte H 310M A
- Corel programs: PSP X9, PSP 2018
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Searching for Droste Effects
Effects -> Reflection Effects -> Feedback might give you some of what you are looking for.
- hartpaul
- ram: 8 Gb
Or the slow way , an example I did back in 2008 with an earlier version of PSP:
1. Started with an original image with a piece of white cardboard on an easel 2. Then copied that image and selected and deleted that white area to leave a hole
3 Then copied the original image and resized and adjusted perspective with the pick tool to fit the hole moved it below the holey layer so it fitted in the hole
4. Repeated that the required number of times to get this final result. The pink layer was moved around to make sure that the images were aligned by showing pink where they needed slight adjustments.
You can see all the layers that were required for the final image - other working layers were turned off and could be deleted.
Takes a bit of time.
- PekyleCA
hartpaul wrote:Or the slow way , an example I did back in 2008 with an earlier version of PSP:
Thanks, I was already aware of this effect, i was more interested in the spiraling type that a lot of fractal artists use through gimp art software (without having to learn how to use the gimp software interface.
Their collapsing spirals can be circular, triangular or even 4 or 5 sided.
Thanks!
- PekyleCA
ConalO
- motherboard: Not Available
- processor: Intel Core i7 1165G7
- Video Card: NVIDIA GeForce MX330
- Hard_Drive_Capacity: 1TB
- Corel programs: PSP 2019 Ult; PSP 2021 Ult;
The below tutorial is from youtube video when you search for Droste effect.
https://www.youtube.com/watch?v=MhWorN2CIoI
The tutorial is very similar to what hartpaul posted above. He also lists a second method using a web app. I haven't tried it but it appears to do something like you are looking to accomplish.
http://www.photospiralysis.com/
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
And perhaps another one you might want to play around with can be found here:
https://sourceforge.net/projects/drdroste/
JoeB
Using PSP 2019 64bit
JoeB
- PekyleCA
Very nice!!Kathy_9 wrote:Effects -> Reflection Effects -> Feedback might give you some of what you are looking for.
part of what I am looking for, now looking for the spiral collapsing - it may be in there, will just have to spend some time playing with it!
Thanks!!
- PekyleCA
ConalO wrote:The below tutorial is from youtube video when you search for Droste effect.
Thanks! I had already found this, and have yet to play with it, was hoping for an "all in one" Paint Shop method.
