Where did it go?
pepegota
motherboard: ASUS TUF Z390-Plus
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Ben Q, "21" LCD
Corel programs: VS 2018, VS 2019, VS 2020
Where did it go?
Post by pepegota »
Look at the two attached screens. One from 2018 and the other from 2019. What happened to "split screen" and "split audio? I found split audio under
"open options panel" but, no split screen. Where are they hiding it? This is not progress!
See comparison files at: https://app.sugarsync.com/wf/D1814182_040_877085820
Using the double click editor to do it is a onerous task.
I see it now. They made it so a clip on the main the main track does not snap all the way to the left. You can move it on the main track
and it will stay put. You can cut off the clip from the left as desired. I wonder what other goodies have been changed?
pepegota
ram: 64 GB
Re: Where did it go?
Post by pepegota »
This is not progress. Before, right click and select split screen after placing the cursor. Now, you can move in from the left side but, only after creating a space-what on earth is going on. Tell me how to split the screen-it should be obvious.
BJC
Hard_Drive_Capacity: 1TB
Corel programs: Videostudio X10 and 2020
Post by BJC »
Do you mean split SCREEN +++ or do you really mean split SCENE
two very different functions
I THINK you mean split by SCENE , in which case double click on the clip in the timeline and the options panel will open allowing you to select 'split by scene'
pepegota
ram: 64 GB
Post by pepegota »
It so obvious why can you see it. How do split a screen-forget that by scene junk. It just is not there!!!!!
There is so many things wrong with this software-unusable. Where did the right click/split screen option disappear too. I got it now. You can move the left or right ends of the clip to where you want and fill in the space. However, the placement problem still exists.
BJC
Post by BJC »
Look at the images YOU have posted above
look at the one for 2018 and in particular at the list displayed
which entry says split screen , count from the top , what number is split screen . I only see split scene
pepegota
ram: 64 GB
Re: W he re did it go?
Post by pepegota »
I got that worked out. I can split the screen (clip) by moving the end handles and closing the gap.
glus
motherboard: MSI Z390
processor: Intel i9-9900K
Video Card: NVIDIA GeForce 2060
Monitor/Display Make & Model: Acer X233H
Corel programs: VideoStudio, Pinnacle Studio
Post by glus »
pepegota wrote:Look at the two attached screens. One from 2018 and the other from 2019. What happened to "split screen" and "split audio? I found split audio under
The missing entries "Split Clip" and "Split Audio" are a known issue. We're sorry for this inconvenience, and we're working to fix the problem as soon as possible.
pepegota
ram: 64 GB
Post by pepegota »
Place the scubber in desired position on the clip and clck on the scissors icon.
Found in the manual pdf.
Keyboard
“Shift S” to split clip
A tool tip on the scissors would be useful
pepegota
ram: 64 GB
Post by pepegota »
It would be nice if a list of basic changes was created. We have two so far
1. Split clip: the scissors icon or S
2. Storyboard clip position switch: move clip to new position and right click space to select remove gap. I h,ope they fix this one.
Better yet, see pages 237-239 of the manual-it's all there.
Why do we keep secrets?
canuck
operating_system: Windows 8.1
Post by canuck »
pepegota wrote:It would be nice if a list of basic changes was created. We have two so far
There is no change with this function; it works exactly the same as in Vs2018
pepegota
ram: 64 GB
Post by pepegota »
As 2019 lacked the old right click split screen option, I looked for one. I did not know about shortcut S because I never had to use it with 2018. I did not know it was in 2018. Others may be have been just as ignorant as I was about the shortcut. Now, it becomes useable.
pepegota wrote:Why do we keep secrets?
The Keyboard shortcut keys are listed in the user guide - as Timeline Shortcuts, a long list
To be honest i never used the Shift + S, so wasn't really aware as i have always used the scissors, they seem easy accessible.
BJC
Post by BJC »
There is in fact no need to use the Shift key, although I agree it does work but the user guide, and I have checked back as far as X9 although I might have an older version somewhere I can check does just say to use the 'S' key and I have just confirmed that the plain S does work very well
so it is not a secret pepegota it has been in the user guides for a very long time
Also pepegota you are still referring to split SCREEN , that is not what you mean and not what you want to do, it is what confused me originally
do you know the difference between split SCENE and split SCREEN two very different functions , perhaps if you used the correct names you might get more useful help , you want split scene (or more correctly split clip since split scene is also another different process )
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Post by tletter »
pepegota wrote:Now, it becomes useable.
You said that you got a refund for VS2019 so how is it now usable to you? Didn't you uninstall your refunded copy?
My word, I've used this "secret" for a long time without reading the manual. Sometimes it's useful to look at the UI and investigate what the icons do rather than simply declaring the new version unusable.
pepegota wrote:Others may be have been just as ignorant as I was about the shortcut.
You can't simply admit that the issue was with your adopting a new version without any preparation or willingness to read the manual.
tletter
