Video studio 2018 crashes after update
I have been using the program for 2 day's now the first day it worked ok, Yesterday it made automaticly an update and now i discover it is crashing when I try to publish or share the video
A window appears with the tekst Dutch [imghttps://forum.corel.com/EN/download/file.php?id=9019&mode=view][/img]
weaver
- processor: intel i7
- Video Card: nvidia Ge Force GF 550 Ti
- sound_card: C.Media
- Hard_Drive_Capacity: 20TB
- Monitor/Display Make & Model: FULL HD
- Corel programs: VS S6,8,10 on W XP, VS X4,6,7,2018
Re: Video studio 2018 crashes after update
It is easy to contact Corel support.
cdoughertycd
- motherboard: ASUS PHTD DELUXE
- processor: 4 Core 2-93 gigahertz Intel Xeon
- ram: 36 GB
- Video Card: AMD Radeon HD 7700 Series
- sound_card: AMD HD Audio
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: Samsung S24B300
- Corel programs: many back to VS 5, all up to 2022 Ult
My Video Studio 2018 Pro keeps crashing!
Candy
Candy
cdoughertycd
- ram: 36 GB
My VS 2018 Pro started crashing sometime since last Windows 10 update. So in effort to fix it tonight and get through a project, I bought upgrade to VS 2018 Ultimate, downloaded and installed but got an error message on install. Tried it anyway, it worked but crashed. So I unstalled it (VS 2018 Ultimate) completely with Windows 10 uninstall, then did the VS Cleanup, then reinstalled VS 2018 Ultimate. During the 2nd install got a message it needed some kind of Win 10 file to work. This popped up in the middle of the install. I clicked on that message to download that Win 10 file, then the install continued and finished. Now on first try of a project it is no longer crashing. Hope this holds up and hope it helps you.
Candy
Candy
Hi Candy
Thanks for the feedback and glad you have managed to get 2018 running again
I guess the message for Gerald is to reinstall the program, first uninstalling using the Cleanup tool from this post
viewtopic.php?f=1&t=59847
Sorry I do not have any other solutions, it could be a problem with the Dutch version.
If the problems persist you should contact Corel Support if you haven’t already done so.
Update from me, I reinstalled the program, then tried again to make a AVC/H.264 or ( .m2t ) video. It worked without a problem BUT ... By the second try crashed again. Now I tried some of the other extensions like wmv or mpeg2 ( dvd ) wel it worked so it seems it only has problems now with larger files like .m2t around 5 gb. but normaly it must be no problem I guess.
cdoughertycd
- ram: 36 GB
Hi Trevor: Thanks for your words of encouragement and all your info on this forum. I managed to finish this project.
Candy
Candy
cdoughertycd
- ram: 36 GB
GeraldH wrote:Update from me, I reinstalled the program, then tried again to make a AVC/H.264 or ( .m2t ) video. It worked without a problem BUT ... By the second try crashed again. Now I tried some of the other extensions like wmv or mpeg2 ( dvd ) wel it worked so it seems it only has problems now with larger files like .m2t around 5 gb. but normaly it must be no problem I guess.
Gerald, this answer might be too simple, but I used to have crashing problems that were due to getting too low on my computer's memory. 20-40 GB left on the hard drive and it would crash, so I deleted a bunch of stuff and the crashes then stopped. This has been a few years ago.
Also did you do the Clean file Trevor posted? What I did was uninstall with Windows 10, then ran the 2018 Clean, then reinstalled VS.
One more thing, are you using the smart proxy file during edit? To turn it on go to Settings, then Performance and click it on. That will help keep gigantic files from "clogging" up things and running "chunky" during edit. Sorry if this is stuff you already know.
Candy
Hi Candy
How did you burn 12 discs? I hope not using Video Studio burner module.
If you first use Video Studio to create an Iso Disc Image file, that file can be used to burn multiple copies, yes we can use Video Studio Tools - Burn from Disc Image but there are other software ImgBurn is worth a try.
If you use the burner module to burn multiple discs it will take longer, render/ multiplex Using a Disc Image literally copies the files to a disc with the extra processes.
With the advantage of playing the iSO using VLC Media Player before burning cuts down on those coasters.
Gerald
Managing your settings and project properties to match the source video can help.
I work a lot with MTS from a Panasonic camcorder with little problems.
Of late have saved the project as a video file rather than burning a disc, then play on the TV using usb stick, so my experience in burning DVD or Bluray with 2018 is limited, I don’t suppose much has changed from earlier versions
If you are burning a disc I would advise that you convert / render the project to a disc compliant video before burning the disc.
Rendering the project in the burner (Convert Title) has been a problem for some and creating the video file is the way to go.
Some info on the burn process here.
http://lata.me.uk/corel/all.htm
Gerald
Hello Candy, no I am, happy with any comment thank you so much. I will try some of the things you mentioned like space on the harddisk. I save the final file on a seperated hardisk. My C:\ dive is an SSD 125gb and only 15 gb is left. Further my ram is 16gb. I will try to clean it up, but I am afraid I have to buy a larger one because I already cleaned it up a few weeks ago and looking at the summery of files there are no very large files left.
I'll keep the clean file in mind and will try out smart proxy.
Thank you so much for your info, much appreciated.
Greetings Gerald
Greetings Gerald
cdoughertycd
- ram: 36 GB
Trevor, thanks again for your info and the burning info link.
I have been burning 12 copies not from a disc image. I will try that, should save a lot of time. I know it's been told to me before but some years ago.
Candy
Candy
cdoughertycd
- ram: 36 GB
Trevor: I burned 12 DVDs from the ISO image file, much "cleaner" and faster. Thanks for your help.
Candy
Candy
cdoughertycd
- ram: 36 GB
Back to 2018 Ultimate issues. Thought I had the crash problem solved but just now had it crash when I was in the sound mixer.
I'll call support tomorrow or Thursday.
Candy
Candy
I'm rench customer. i'm working with vs 2018 ultimate . and i think update or not update it's not the problem.
Vs2018 is crashing anyway regularly. Go to the application-level event logs and you'll have details like this:
Nom de l’application défaillante vstudio.exe, version : 21.4.0.165, horodatage : 0x5beb0845
Nom du module défaillant : HerDocdll.dll, version : 21.4.0.165, horodatage : 0x5beb0085
Code d’exception : 0xc0000005
Décalage d’erreur : 0x00000000000f4415
ID du processus défaillant : 0x3824
Heure de début de l’application défaillante : 0x01d4b9b9ab88353e
Chemin d’accès de l’application défaillante : C:\Program Files\Corel\Corel VideoStudio 2018\vstudio.exe
Chemin d’accès du module défaillant: C:\Program Files\Corel\Corel VideoStudio 2018\HerDocdll.dll
ID de rapport : b9983611-ac1b-4ecd-8a9a-4ae87800477d
Nom complet du package défaillant :
ID de l’application relative au package défaillant :
Détecteur d'erreurs 1451536535252988590, type 4
Nom d’événement : APPCRASH
Réponse : Non disponible
ID de CAB : 0
Signature du problème :
P1 : vstudio.exe
P2 : 21.4.0.165
P3 : 5beb0845
P4 : HerDocdll.dll
P5 : 21.4.0.165
P6 : 5beb0085
P7 : c0000005
P8 : 00000000000f4415
P9 :
P10 :
Fichiers joints :
\\?\C:\Windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Dlna\DeviceIcons\92519d4f-c676-4b45-bc43-97127eb2753d_1.jpg
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB6EE.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERBB73.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERBB94.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERBB92.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERBBB2.tmp.txt
Ces fichiers sont peut-être disponibles ici :
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_vstudio.exe_9d6214c8b2a72d1bab8582b9d1a501893a5517d_f20fa44b_39d320a5
Symbole d’analyse :
Nouvelle recherche de la solution : 0
Statut du rapport : 268435456
Récipient avec hachage : 1257e1038487e7e28424e4c9ca4172ae
And also this :
Version=1
EventType=APPCRASH
EventTime=131934534022952051
ReportType=2
Consent=1
UploadTime=131934534035256363
ReportStatus=268435456
ReportIdentifier=ed89273c-3bda-4433-8ae9-5ec69a1fdb8b
IntegratorReportIdentifier=b9983611-ac1b-4ecd-8a9a-4ae87800477d
Wow64Host=34404
NsAppName=vstudio.exe
OriginalFilename=Vstudio.EXE
AppSessionGuid=00003824-0001-0018-3e35-88abb9b9d401
TargetAppId=W:0006f68cc4c251b3397018f3a1232cf3d46800000904!0000ecd1434ee4c6c3a348e21e3eba71fae8754a58de!vstudio.exe
TargetAppVer=2018//11//13:17:22:13!93eba5!vstudio.exe
BootId=4294967295
TargetAsId=461
UserImpactVector=271585552
IsFatal=1
EtwNonCollectReason=1
Response.BucketId=1257e1038487e7e28424e4c9ca4172ae
Response.BucketTable=4
Response.LegacyBucketId=1451536535252988590
Response.type=4
Sig[0].Name=Nom de l’application
Sig[0].Value=vstudio.exe
Sig[1].Name=Version de l’application
Sig[1].Value=21.4.0.165
Sig[2].Name=Horodatage de l’application
Sig[2].Value=5beb0845
Sig[3].Name=Nom du module par défaut
Sig[3].Value=HerDocdll.dll
Sig[4].Name=Version du module par défaut
Sig[4].Value=21.4.0.165
Sig[5].Name=Horodateur du module par défaut
Sig[5].Value=5beb0085
Sig[6].Name=Code de l’exception
Sig[6].Value=c0000005
Sig[7].Name=Décalage de l’exception
Sig[7].Value=00000000000f4415
DynamicSig[1].Name=Version du système
DynamicSig[1].Value=10.0.17763.2.0.0.768.101
DynamicSig[2].Name=Identificateur de paramètres régionaux
DynamicSig[2].Value=1036
DynamicSig[22].Name=Information supplémentaire n° 1
DynamicSig[22].Value=1d11
DynamicSig[23].Name=Information supplémentaire n° 2
DynamicSig[23].Value=1d1192a4508f25757dc4a627d6d5d08f
DynamicSig[24].Name=Information supplémentaire n° 3
DynamicSig[24].Value=af1f
DynamicSig[25].Name=Information supplémentaire n° 4
DynamicSig[25].Value=af1fe81e0c4654262c7ac75aef590dbc
UI[2]=C:\Program Files\Corel\Corel VideoStudio 2018\vstudio.exe
LoadedModule[0]=C:\Program Files\Corel\Corel VideoStudio 2018\vstudio.exe
LoadedModule[1]=C:\Windows\SYSTEM32\ntdll.dll
LoadedModule[2]=C:\Windows\System32\KERNEL32.DLL
LoadedModule[3]=C:\Windows\System32\KERNELBASE.dll
LoadedModule[4]=C:\Windows\System32\CRYPT32.dll
LoadedModule[5]=C:\Windows\System32\ucrtbase.dll
LoadedModule[6]=C:\Windows\System32\MSASN1.dll
LoadedModule[7]=C:\Windows\System32\SETUPAPI.dll
LoadedModule[8]=C:\Windows\System32\msvcrt.dll
LoadedModule[9]=C:\Windows\System32\cfgmgr32.dll
LoadedModule[10]=C:\Windows\System32\RPCRT4.dll
LoadedModule[11]=C:\Windows\System32\bcrypt.dll
LoadedModule[12]=C:\Windows\System32\SHLWAPI.dll
LoadedModule[13]=C:\Windows\System32\combase.dll
LoadedModule[14]=C:\Windows\System32\bcryptPrimitives.dll
LoadedModule[15]=C:\Windows\System32\GDI32.dll
LoadedModule[16]=C:\Windows\System32\gdi32full.dll
LoadedModule[17]=C:\Windows\System32\msvcp_win.dll
LoadedModule[18]=C:\Windows\System32\USER32.dll
LoadedModule[19]=C:\Windows\System32\win32u.dll
LoadedModule[20]=C:\Program Files\Corel\Corel VideoStudio 2018\UiaProvider.dll
LoadedModule[21]=C:\Windows\System32\IMM32.dll
LoadedModule[22]=C:\Windows\System32\OLEAUT32.dll
LoadedModule[23]=C:\Windows\System32\COMDLG32.dll
LoadedModule[24]=C:\Windows\System32\shcore.dll
LoadedModule[25]=C:\Windows\System32\SHELL32.dll
LoadedModule[26]=C:\Program Files\Corel\Corel VideoStudio 2018\u32Comm.dll
LoadedModule[27]=C:\Windows\SYSTEM32\WINMM.dll
LoadedModule[28]=C:\Windows\System32\ADVAPI32.dll
LoadedModule[29]=C:\Windows\System32\windows.storage.dll
LoadedModule[30]=C:\Windows\System32\sechost.dll
LoadedModule[31]=C:\Windows\System32\profapi.dll
LoadedModule[32]=C:\Windows\System32\powrprof.dll
LoadedModule[33]=C:\Windows\System32\kernel.appcore.dll
LoadedModule[34]=C:\Windows\SYSTEM32\MSVFW32.dll
LoadedModule[35]=C:\Windows\System32\cryptsp.dll
LoadedModule[36]=C:\Windows\SYSTEM32\mfc110.dll
LoadedModule[37]=C:\Windows\System32\ole32.dll
LoadedModule[38]=C:\Windows\SYSTEM32\MSVCR110.dll
LoadedModule[39]=C:\Windows\SYSTEM32\SensApi.dll
LoadedModule[40]=C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.17763.292_none_369c2a9961b56089\gdiplus.dll
LoadedModule[41]=C:\Windows\SYSTEM32\d3d9.dll
LoadedModule[42]=C:\Program Files\Corel\Corel VideoStudio 2018\uTimeCode.dll
LoadedModule[43]=C:\Program Files\Corel\Corel VideoStudio 2018\MaskToolDB.dll
LoadedModule[44]=C:\Windows\SYSTEM32\dbghelp.dll
LoadedModule[45]=C:\Program Files\Corel\Corel VideoStudio 2018\uBasePopupWnd.dll
LoadedModule[46]=C:\Program Files\Corel\Corel VideoStudio 2018\IPN.dll
LoadedModule[47]=C:\Windows\SYSTEM32\MSIMG32.dll
LoadedModule[48]=C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.17763.292_none_05b137b40722e6bb\COMCTL32.dll
LoadedModule[49]=C:\Windows\SYSTEM32\MPR.dll
LoadedModule[50]=C:\Windows\SYSTEM32\WINMMBASE.dll
LoadedModule[51]=C:\Windows\SYSTEM32\UxTheme.dll
LoadedModule[52]=C:\Windows\SYSTEM32\MSVCP110.dll
LoadedModule[53]=C:\Windows\SYSTEM32\VCOMP110.DLL
LoadedModule[54]=C:\Windows\SYSTEM32\WININET.dll
LoadedModule[55]=C:\Windows\SYSTEM32\dwmapi.dll
LoadedModule[56]=C:\Program Files\Corel\Corel VideoStudio 2018\u32Base.dll
LoadedModule[57]=C:\Windows\SYSTEM32\WINHTTP.dll
LoadedModule[58]=C:\Program Files\Corel\Corel VideoStudio 2018\U32BROWS.DLL
LoadedModule[59]=C:\Program Files\Corel\Corel VideoStudio 2018\MaskToolUser.dll
LoadedModule[60]=C:\Program Files\Corel\Corel VideoStudio 2018\uAfxUnknown.dll
LoadedModule[61]=C:\Program Files\Corel\Corel VideoStudio 2018\Vcvrt32.dll
LoadedModule[62]=C:\Program Files\Corel\Corel VideoStudio 2018\HerDocdll.dll
LoadedModule[63]=C:\Program Files\Corel\Corel VideoStudio 2018\U32VIDEO.dll
LoadedModule[64]=C:\Program Files\Corel\Corel VideoStudio 2018\uDVDUser.dll
LoadedModule[65]=C:\Windows\System32\PSAPI.DLL
LoadedModule[66]=C:\Program Files\Corel\Corel VideoStudio 2018\uvBase.dll
LoadedModule[67]=C:\Program Files\Corel\Corel VideoStudio 2018\ulDARMgr.dll
LoadedModule[68]=C:\Program Files\Corel\Corel VideoStudio 2018\uVeCfg.dll
LoadedModule[69]=C:\Program Files\Corel\Corel VideoStudio 2018\ukMgr.dll
LoadedModule[70]=C:\Program Files\Corel\Corel VideoStudio 2018\u32File.dll
LoadedModule[71]=C:\Program Files\Corel\Corel VideoStudio 2018\upl.dll
LoadedModule[72]=C:\Program Files\Corel\Corel VideoStudio 2018\UCIMG.dll
LoadedModule[73]=C:\Program Files\Corel\Corel VideoStudio 2018\u32Cvt.dll
LoadedModule[74]=C:\Program Files\Corel\Corel VideoStudio 2018\ScoreFitterMgr.dll
LoadedModule[75]=C:\Program Files\Corel\Corel VideoStudio 2018\FisheyeTransform.dll
LoadedModule[76]=C:\Windows\SYSTEM32\d3d11.dll
LoadedModule[77]=C:\Windows\SYSTEM32\QUARTZ.dll
LoadedModule[78]=C:\Program Files\Corel\Corel VideoStudio 2018\opencv_world310.dll
LoadedModule[79]=C:\Program Files\Corel\Corel VideoStudio 2018\UFCSTATU.dll
LoadedModule[80]=C:\Windows\SYSTEM32\dxgi.dll
LoadedModule[81]=C:\Program Files\Corel\Corel VideoStudio 2018\MSVCR120.dll
LoadedModule[82]=C:\Program Files\Corel\Corel VideoStudio 2018\MSVCP120.dll
LoadedModule[83]=C:\Program Files\Corel\Corel VideoStudio 2018\VCAMP120.DLL
LoadedModule[84]=C:\Program Files\Corel\Corel VideoStudio 2018\UFCVECOMM.dll
LoadedModule[85]=C:\Windows\SYSTEM32\AVIFIL32.dll
LoadedModule[86]=C:\Windows\SYSTEM32\AVICAP32.dll
LoadedModule[87]=C:\Windows\SYSTEM32\VERSION.dll
LoadedModule[88]=C:\Windows\SYSTEM32\MSACM32.dll
LoadedModule[89]=C:\Program Files\Corel\Corel VideoStudio 2018\uipp.dll
LoadedModule[90]=C:\Program Files\Corel\Corel VideoStudio 2018\uvMaskTrackLOT.dll
LoadedModule[91]=C:\Program Files\Corel\Corel VideoStudio 2018\svml_dispmd.dll
LoadedModule[92]=C:\Program Files\Corel\Corel VideoStudio 2018\AIKRC.dll
LoadedModule[93]=C:\Windows\SYSTEM32\DCIMAN32.DLL
LoadedModule[94]=C:\Program Files\Corel\Corel VideoStudio 2018\uDVDUserR.dll
LoadedModule[95]=C:\Program Files\Corel\Corel VideoStudio 2018\ufctxeff.dll
LoadedModule[96]=C:\Program Files\Corel\Corel VideoStudio 2018\VioRC.dll
LoadedModule[97]=C:\Program Files\Corel\Corel VideoStudio 2018\U32MISC.dll
LoadedModule[98]=C:\Program Files\Corel\Corel VideoStudio 2018\MUIHelper.dll
LoadedModule[99]=C:\Program Files\Corel\Corel VideoStudio 2018\aft_plug\VST\NewBlue Corel Scrubbers Bundle64.pkc
LoadedModule[100]=C:\Windows\system32\CRYPTBASE.DLL
LoadedModule[101]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\AIKRC.dll
LoadedModule[102]=C:\Program Files\Corel\Corel VideoStudio 2018\AIKRC2.DLL
LoadedModule[103]=C:\Program Files\Corel\Corel VideoStudio 2018\uBaseObject.dll
LoadedModule[104]=C:\Program Files\Corel\Corel VideoStudio 2018\UFCCOLOR.dll
LoadedModule[105]=C:\Windows\system32\RICHED32.DLL
LoadedModule[106]=C:\Windows\system32\RICHED20.dll
LoadedModule[107]=C:\Windows\system32\USP10.dll
LoadedModule[108]=C:\Windows\system32\msls31.dll
LoadedModule[109]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\herrc.dll
LoadedModule[110]=C:\Program Files\Corel\Corel VideoStudio 2018\UFCLIB.dll
LoadedModule[111]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\u32ZLib.dll
LoadedModule[112]=C:\Windows\System32\clbcatq.dll
LoadedModule[113]=C:\Windows\SYSTEM32\ntmarta.dll
LoadedModule[114]=C:\Windows\system32\WMVCore.DLL
LoadedModule[115]=C:\Windows\system32\mfperfhelper.dll
LoadedModule[116]=C:\Windows\system32\WMASF.DLL
LoadedModule[117]=C:\Windows\System32\MSCTF.dll
LoadedModule[118]=C:\Windows\System32\WS2_32.dll
LoadedModule[119]=C:\WINDOWS\SYSTEM32\SspiCli.dll
LoadedModule[120]=C:\Windows\System32\DevDispItemProvider.dll
LoadedModule[121]=C:\Windows\System32\MMDevApi.dll
LoadedModule[122]=C:\Windows\system32\DEVOBJ.dll
LoadedModule[123]=C:\Windows\system32\PROPSYS.dll
LoadedModule[124]=C:\Windows\SYSTEM32\IPHLPAPI.DLL
LoadedModule[125]=C:\Windows\System32\NSI.dll
LoadedModule[126]=C:\Windows\SYSTEM32\dhcpcsvc6.DLL
LoadedModule[127]=C:\Windows\SYSTEM32\dhcpcsvc.DLL
LoadedModule[128]=C:\Windows\SYSTEM32\DNSAPI.dll
LoadedModule[129]=C:\Windows\SYSTEM32\WINNSI.DLL
LoadedModule[130]=C:\Windows\SYSTEM32\MFPlat.DLL
LoadedModule[131]=C:\Windows\SYSTEM32\RTWorkQ.DLL
LoadedModule[132]=C:\Windows\SYSTEM32\DPAPI.dll
LoadedModule[133]=C:\Windows\system32\rsaenh.dll
LoadedModule[134]=C:\Program Files\Corel\Corel VideoStudio 2018\PASMUtility.dll
LoadedModule[135]=C:\Windows\system32\mfc110u.dll
LoadedModule[136]=C:\Program Files\Corel\PASMUtility\v1\PASMUTILITY.dll
LoadedModule[137]=C:\PROGRAM FILES\COREL\COREL VIDEOSTUDIO 2018\omnitracking.dll
LoadedModule[138]=C:\WINDOWS\SYSTEM32\mfc120u.dll
LoadedModule[139]=C:\WINDOWS\SYSTEM32\oledlg.dll
LoadedModule[140]=C:\WINDOWS\SYSTEM32\WINSPOOL.DRV
LoadedModule[141]=C:\WINDOWS\SYSTEM32\OLEACC.dll
LoadedModule[142]=C:\Windows\System32\imagehlp.dll
LoadedModule[143]=C:\Windows\SYSTEM32\iertutil.dll
LoadedModule[144]=C:\Windows\system32\ondemandconnroutehelper.dll
LoadedModule[145]=C:\Windows\system32\mswsock.dll
LoadedModule[146]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\PCUDataIntl.dll
LoadedModule[147]=C:\Program Files\Corel\Corel VideoStudio 2018\PsiClient.dll
LoadedModule[148]=C:\Windows\System32\msxml3.dll
LoadedModule[149]=C:\Windows\SYSTEM32\urlmon.dll
LoadedModule[150]=C:\Windows\System32\rasadhlp.dll
LoadedModule[151]=C:\Program Files\Corel\Corel VideoStudio 2018\IPP.dll
LoadedModule[152]=C:\Program Files\Corel\Corel VideoStudio 2018\u32Cfg.dll
LoadedModule[153]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\u32Prod.dll
LoadedModule[154]=C:\Program Files\Corel\Corel VideoStudio 2018\uDrawingTool.dll
LoadedModule[155]=C:\Windows\System32\mshtml.dll
LoadedModule[156]=C:\Windows\system32\netutils.dll
LoadedModule[157]=C:\Windows\system32\wkscli.dll
LoadedModule[158]=C:\Program Files\Corel\Corel VideoStudio 2018\uLauncher.dll
LoadedModule[159]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\uLauncherRC.dll
LoadedModule[160]=C:\Windows\SYSTEM32\srpapi.dll
LoadedModule[161]=C:\Windows\SYSTEM32\msIso.dll
LoadedModule[162]=C:\Windows\system32\msimtf.dll
LoadedModule[163]=C:\Windows\SYSTEM32\TextInputFramework.dll
LoadedModule[164]=C:\Windows\SYSTEM32\CoreUIComponents.dll
LoadedModule[165]=C:\Windows\SYSTEM32\CoreMessaging.dll
LoadedModule[166]=C:\Windows\SYSTEM32\wintypes.dll
LoadedModule[167]=C:\Windows\SYSTEM32\edputil.dll
LoadedModule[168]=C:\Windows\system32\WLDP.DLL
LoadedModule[169]=C:\Windows\System32\WINTRUST.dll
LoadedModule[170]=C:\Windows\SYSTEM32\ieapfltr.dll
LoadedModule[171]=C:\Windows\SYSTEM32\CLDAPI.dll
LoadedModule[172]=C:\Windows\SYSTEM32\FLTLIB.DLL
LoadedModule[173]=C:\Windows\system32\dataexchange.dll
LoadedModule[174]=C:\Windows\system32\dcomp.dll
LoadedModule[175]=C:\Windows\SYSTEM32\twinapi.appcore.dll
LoadedModule[176]=C:\Windows\SYSTEM32\RMCLIENT.dll
LoadedModule[177]=C:\Windows\system32\Bcp47Langs.dll
LoadedModule[178]=C:\Windows\system32\USERENV.dll
LoadedModule[179]=C:\Windows\system32\jscript9.dll
LoadedModule[180]=C:\Windows\SYSTEM32\d2d1.dll
LoadedModule[181]=C:\Windows\SYSTEM32\DWrite.dll
LoadedModule[182]=C:\Windows\system32\d3d10warp.dll
LoadedModule[183]=C:\Program Files\Corel\Corel VideoStudio 2018\uTextCfg.dll
LoadedModule[184]=C:\Program Files\Corel\Corel VideoStudio 2018\libiomp5md.dll
LoadedModule[185]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\VioRC.dll
LoadedModule[186]=c:\program files\corel\corel videostudio 2018\vio\Uvavi.vio
LoadedModule[187]=C:\Program Files\Corel\Corel VideoStudio 2018\libmmd.dll
LoadedModule[188]=C:\Windows\system32\imaadp32.acm
LoadedModule[189]=C:\Windows\system32\msadp32.acm
LoadedModule[190]=C:\Windows\system32\msg711.acm
LoadedModule[191]=C:\Windows\system32\msgsm32.acm
LoadedModule[192]=C:\Windows\System32\l3codeca.acm
LoadedModule[193]=C:\PROGRA~1\Corel\CORELV~1\Dvacm.acm
LoadedModule[194]=C:\Windows\System32\coml2.dll
LoadedModule[195]=C:\Program Files\Corel\Corel VideoStudio 2018\ufctmtg.dll
LoadedModule[196]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\HerDocRC.dll
LoadedModule[197]=C:\Program Files\Corel\Corel VideoStudio 2018\ulRender.dll
LoadedModule[198]=C:\Program Files\Corel\Corel VideoStudio 2018\uRenderS.dll
LoadedModule[199]=C:\Program Files\Corel\Corel VideoStudio 2018\UrenderA.dll
LoadedModule[200]=C:\Program Files\Corel\Corel VideoStudio 2018\uRenderGPU.dll
LoadedModule[201]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\VRMGR.dll
LoadedModule[202]=C:\Windows\system32\igdumdim64.dll
LoadedModule[203]=C:\Windows\system32\igc64.dll
LoadedModule[204]=C:\Program Files\Corel\Corel VideoStudio 2018\d3dx9_36.dll
LoadedModule[205]=C:\Windows\system32\dxva2.dll
LoadedModule[206]=C:\Program Files\Corel\Corel VideoStudio 2018\uRenderMT.dll
LoadedModule[207]=C:\Program Files\Corel\Corel VideoStudio 2018\ulPPMgr.dll
LoadedModule[208]=C:\Program Files\Corel\Corel VideoStudio 2018\ulPrev.dll
LoadedModule[209]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\ulPrevRC.dll
LoadedModule[210]=C:\Program Files\Corel\Corel VideoStudio 2018\upbPlug.dll
LoadedModule[211]=C:\Program Files\Corel\Corel VideoStudio 2018\Vepb40.dll
LoadedModule[212]=C:\Program Files\Corel\Corel VideoStudio 2018\uSurround.dll
LoadedModule[213]=C:\Program Files\Corel\Corel VideoStudio 2018\U32mpb.dll
LoadedModule[214]=C:\Program Files\Corel\Corel VideoStudio 2018\uvgrc.dll
LoadedModule[215]=C:\Program Files\Corel\Corel VideoStudio 2018\uvDV.dll
LoadedModule[216]=C:\Program Files\Corel\Corel VideoStudio 2018\U32mpbm.dll
LoadedModule[217]=C:\Program Files\Corel\Corel VideoStudio 2018\sepa.dll
LoadedModule[218]=C:\Program Files\Corel\Corel VideoStudio 2018\UPFMGR.dll
LoadedModule[219]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\upfMgrRC.dll
LoadedModule[220]=C:\Windows\system32\nvcuda.dll
LoadedModule[221]=C:\Windows\system32\nvfatbinaryLoader.dll
LoadedModule[222]=C:\Program Files\Corel\Corel VideoStudio 2018\uAMModule.dll
LoadedModule[223]=C:\Program Files\Corel\Corel VideoStudio 2018\uvSmartProxyMgr.dll
LoadedModule[224]=C:\Program Files\Corel\Corel VideoStudio 2018\uvUser.dll
LoadedModule[225]=C:\Program Files\Corel\Corel VideoStudio 2018\UIShareTools.dll
LoadedModule[226]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\UvUserRC.dll
LoadedModule[227]=C:\Windows\system32\WindowsCodecs.dll
LoadedModule[228]=C:\Program Files\Corel\Corel VideoStudio 2018\uGDIPlusTool.dll
LoadedModule[229]=C:\Program Files\Corel\Corel VideoStudio 2018\u32Fido.dll
LoadedModule[230]=C:\Windows\System32\fwpuclnt.dll
LoadedModule[231]=C:\Windows\SYSTEM32\WINSTA.dll
LoadedModule[232]=c:\program files\corel\corel videostudio 2018\vio\uvMP4.vio
LoadedModule[233]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\MPEG_VioRC.dll
LoadedModule[234]=C:\Program Files\Corel\Corel VideoStudio 2018\uvMP4Drv.dll
LoadedModule[235]=C:\Program Files\Corel\Corel VideoStudio 2018\MP4FileLibU.dll
LoadedModule[236]=C:\Program Files\Corel\Corel VideoStudio 2018\u32txEx.dll
LoadedModule[237]=C:\Program Files\Corel\Corel VideoStudio 2018\u32uscUI.dll
LoadedModule[238]=C:\Program Files\Corel\Corel VideoStudio 2018\UFCUNDO.dll
LoadedModule[239]=C:\Program Files\Corel\Corel VideoStudio 2018\ufcpnlbr.dll
LoadedModule[240]=C:\Program Files\Corel\Corel VideoStudio 2018\uvCapModuleNotify.dll
LoadedModule[241]=C:\Windows\system32\schannel.DLL
LoadedModule[242]=C:\Windows\system32\mskeyprotect.dll
LoadedModule[243]=C:\Windows\system32\ncrypt.dll
LoadedModule[244]=C:\Windows\system32\NTASN1.dll
LoadedModule[245]=C:\Windows\System32\cryptnet.dll
LoadedModule[246]=C:\Windows\system32\ncryptsslp.dll
LoadedModule[247]=C:\Program Files\Corel\Corel VideoStudio 2018\VSTempTrans.dll
LoadedModule[248]=C:\Program Files\Corel\Corel VideoStudio 2018\uDVDUserEx40Lite.dll
LoadedModule[249]=C:\Program Files\Corel\Corel VideoStudio 2018\uVideoTool.dll
LoadedModule[250]=C:\Program Files\Corel\Corel VideoStudio 2018\UFCVEBUF.dll
LoadedModule[251]=C:\Program Files\Corel\Corel VideoStudio 2018\uvVarSpeedUser.dll
LoadedModule[252]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\uvVarSpeedRC.dll
LoadedModule[253]=C:\Program Files\Corel\Corel VideoStudio 2018\Vft32.dll
LoadedModule[254]=C:\Program Files\Corel\Corel VideoStudio 2018\MSPEEffectFunc.dll
LoadedModule[255]=C:\Program Files\Corel\Corel VideoStudio 2018\DiGeneral.dll
LoadedModule[256]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\vftrc.dll
LoadedModule[257]=C:\Program Files\Corel\Corel VideoStudio 2018\DrawImageMgr.dll
LoadedModule[258]=C:\Program Files\Corel\Corel VideoStudio 2018\ConverDib.dll
LoadedModule[259]=C:\Program Files\Corel\Corel VideoStudio 2018\ulibjpg.dll
LoadedModule[260]=c:\program files\corel\corel videostudio 2018\vio\uvmpeg.vio
LoadedModule[261]=C:\Program Files\Corel\Corel VideoStudio 2018\uvHTMPEG2.dll
LoadedModule[262]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\ac3aout.dll
LoadedModule[263]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\pcmaout.dll
LoadedModule[264]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\mpgaout.dll
LoadedModule[265]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\mpgvout.dll
LoadedModule[266]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\mpgmux.dll
LoadedModule[267]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\mpg_dlg.dll
LoadedModule[268]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\mpgcheck.dll
LoadedModule[269]=C:\Program Files\Corel\Corel VideoStudio 2018\uvMPEGRO.dll
LoadedModule[270]=c:\program files\corel\corel videostudio 2018\vio\uvuis.vio
LoadedModule[271]=C:\Program Files\Corel\Corel VideoStudio 2018\ulProjectIO.dll
LoadedModule[272]=C:\Program Files\Corel\Corel VideoStudio 2018\eio\EIO.DLL
LoadedModule[273]=C:\Program Files\Corel\Corel VideoStudio 2018\eio\AFT.EIO
LoadedModule[274]=C:\Program Files\Corel\Corel VideoStudio 2018\eio\VST.EIO
LoadedModule[275]=C:\Program Files\Corel\Corel VideoStudio 2018\ulmp4lib.dll
LoadedModule[276]=C:\Program Files\Corel\Corel VideoStudio 2018\ulMjpegDecode.dll
LoadedModule[277]=c:\program files\corel\corel videostudio 2018\vio\uvWmf.vio
LoadedModule[278]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\uvVIOCapShareModuleRC.dll
LoadedModule[279]=C:\Windows\system32\mlang.dll
LoadedModule[280]=C:\Program Files\Corel\Corel VideoStudio 2018\uvWMEProfile.dll
LoadedModule[281]=C:\Windows\system32\msdmo.dll
LoadedModule[282]=C:\Windows\System32\wmvdecod.dll
LoadedModule[283]=C:\Program Files\Corel\Corel VideoStudio 2018\FIO\u32Jpg.fio
LoadedModule[284]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\FIO\FIORC.DLL
LoadedModule[285]=C:\Program Files\Corel\Corel VideoStudio 2018\uExifLib.dll
LoadedModule[286]=C:\Program Files\Corel\Corel VideoStudio 2018\UfcAud.dll
LoadedModule[287]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\ufcaudrc.dll
LoadedModule[288]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\iEncoder.dll
LoadedModule[289]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\DsVEncHP.dll
LoadedModule[290]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\MpgVEncHP.dll
LoadedModule[291]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\ulcudaenc.dll
LoadedModule[292]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\H264VEncHP.dll
LoadedModule[293]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\mpegin.dll
LoadedModule[294]=C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG\mcmpgdec.dll
LoadedModule[295]=C:\Program Files\Corel\Corel VideoStudio 2018\uvSEPA.dll
LoadedModule[296]=C:\Program Files\Corel\Corel VideoStudio 2018\Drawing\DrawDV.dra
LoadedModule[297]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\DrawingRC.dll
LoadedModule[298]=C:\Windows\System32\devenum.dll
LoadedModule[299]=C:\Windows\System32\mfksproxy.dll
LoadedModule[300]=C:\Windows\system32\ATL.DLL
LoadedModule[301]=C:\Windows\SYSTEM32\MFSENSORGROUP.dll
LoadedModule[302]=C:\Windows\System32\ksproxy.ax
LoadedModule[303]=C:\Windows\system32\ksuser.dll
LoadedModule[304]=C:\Windows\SYSTEM32\policymanager.dll
LoadedModule[305]=C:\Windows\SYSTEM32\msvcp110_win.dll
LoadedModule[306]=C:\Windows\System32\vidcap.ax
LoadedModule[307]=C:\Windows\System32\kswdmcap.ax
LoadedModule[308]=C:\Windows\system32\MFC42.dll
LoadedModule[309]=C:\Program Files\Corel\Corel VideoStudio 2018\Drawing\DrawWinDevice.dra
LoadedModule[310]=C:\Program Files\Corel\Corel VideoStudio 2018\ULSCRUB.dll
LoadedModule[311]=C:\Program Files\Corel\Corel VideoStudio 2018\u32usp.dll
LoadedModule[312]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\U32USPRC.dll
LoadedModule[313]=C:\Program Files\Corel\Corel VideoStudio 2018\upppmgr.dll
LoadedModule[314]=C:\Program Files\Corel\Corel VideoStudio 2018\PPP\DVRecording.ppp
LoadedModule[315]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\PPPRC.dll
LoadedModule[316]=C:\Program Files\Corel\Corel VideoStudio 2018\PPP\DvrMS.dll
LoadedModule[317]=C:\Program Files\Corel\Corel VideoStudio 2018\PPP\DvrHDV.ppp
LoadedModule[318]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\CU3PDVR_HDV_RC.dll
LoadedModule[319]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\ufctxeffrc.dll
LoadedModule[320]=C:\Program Files\Corel\Corel VideoStudio 2018\Veui32.dll
LoadedModule[321]=C:\Program Files\Corel\Corel VideoStudio 2018\KeyFrameModule.dll
LoadedModule[322]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\KEYFRAMEMODULERC.dll
LoadedModule[323]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\veui32rc.dll
LoadedModule[324]=C:\Program Files\Corel\Corel VideoStudio 2018\ulTitleMgr.dll
LoadedModule[325]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\TitlePlugRC.dll
LoadedModule[326]=C:\Program Files\Corel\Corel VideoStudio 2018\ulTitlePlug.dll
LoadedModule[327]=C:\Program Files\Corel\Corel VideoStudio 2018\ufctxt.dll
LoadedModule[328]=C:\Program Files\Corel\Corel VideoStudio 2018\ufcvren.dll
LoadedModule[329]=C:\Program Files\Corel\Corel VideoStudio 2018\ufcpath.dll
LoadedModule[330]=C:\Program Files\Corel\Corel VideoStudio 2018\ulTitleEng.dll
LoadedModule[331]=C:\Program Files\Corel\Corel VideoStudio 2018\motion_plug\Curve.dll
LoadedModule[332]=C:\Program Files\Corel\Corel VideoStudio 2018\motion_plug\Drop.dll
LoadedModule[333]=C:\Program Files\Corel\Corel VideoStudio 2018\motion_plug\Fade.dll
LoadedModule[334]=C:\Program Files\Corel\Corel VideoStudio 2018\motion_plug\Fly.dll
LoadedModule[335]=C:\Program Files\Corel\Corel VideoStudio 2018\motion_plug\PathAnim.dll
LoadedModule[336]=C:\Program Files\Corel\Corel VideoStudio 2018\motion_plug\Popup.dll
LoadedModule[337]=C:\Program Files\Corel\Corel VideoStudio 2018\motion_plug\Turn.dll
LoadedModule[338]=C:\Program Files\Corel\Corel VideoStudio 2018\motion_plug\Zoom.dll
LoadedModule[339]=C:\Program Files\Corel\Corel VideoStudio 2018\ulColorBar.dll
LoadedModule[340]=C:\Program Files\Corel\Corel VideoStudio 2018\uHerObjs.dll
LoadedModule[341]=C:\Program Files\Corel\Corel VideoStudio 2018\uTextTool.dll
LoadedModule[342]=C:\Program Files\Corel\Corel VideoStudio 2018\uTextUser.dll
LoadedModule[343]=C:\Program Files\Corel\Corel VideoStudio 2018\ulTitleData.dll
LoadedModule[344]=C:\Program Files\Corel\Corel VideoStudio 2018\aematrix.dll
LoadedModule[345]=C:\Program Files\Corel\Corel VideoStudio 2018\aemath.dll
LoadedModule[346]=C:\Program Files\Corel\Corel VideoStudio 2018\upatheng.dll
LoadedModule[347]=C:\Program Files\Corel\Corel VideoStudio 2018\UEIP.dll
LoadedModule[348]=C:\Windows\System32\ieframe.dll
LoadedModule[349]=C:\Windows\system32\NETAPI32.dll
LoadedModule[350]=C:\Windows\system32\Secur32.dll
LoadedModule[351]=C:\Windows\System32\UIAnimation.dll
LoadedModule[352]=C:\Windows\system32\windowscodecsext.dll
LoadedModule[353]=C:\Windows\System32\msxml6.dll
LoadedModule[354]=C:\Windows\System32\uiautomationcore.dll
LoadedModule[355]=c:\program files\corel\corel videostudio 2018\vio\uvwav.vio
LoadedModule[356]=C:\Program Files\Corel\Corel VideoStudio 2018\FIO\u32Bmp.fio
LoadedModule[357]=C:\Program Files\Corel\Corel VideoStudio 2018\FIO\FIORC2.DLL
LoadedModule[358]=C:\Program Files\Corel\VideoStudio 3D Title Editor\Title3DEngine.dll
LoadedModule[359]=C:\PROGRAM FILES\COREL\VIDEOSTUDIO 3D TITLE EDITOR\Title3DRenderDX11.dll
LoadedModule[360]=C:\WINDOWS\SYSTEM32\D3DCOMPILER_47.dll
LoadedModule[361]=c:\program files\corel\corel videostudio 2018\vio\uvmp3.vio
LoadedModule[362]=C:\Program Files\Corel\Corel VideoStudio 2018\uvPointTrackingMgr.dll
LoadedModule[363]=C:\Windows\system32\wdmaud.drv
LoadedModule[364]=C:\Windows\system32\AVRT.dll
LoadedModule[365]=C:\Windows\system32\AUDIOSES.DLL
LoadedModule[366]=C:\Windows\system32\msacm32.drv
LoadedModule[367]=C:\Windows\system32\midimap.dll
LoadedModule[368]=C:\Program Files\Corel\Corel VideoStudio 2018\PexExif.dll
LoadedModule[369]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\PEXEXIF_Res.dll
LoadedModule[370]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\uFioUtil.dll
LoadedModule[371]=C:\Program Files\Corel\Corel VideoStudio 2018\uCodecUtils.dll
LoadedModule[372]=C:\Program Files\Corel\Corel VideoStudio 2018\IVIVIDEO.ax
LoadedModule[373]=C:\Windows\system32\DDRAW.dll
LoadedModule[374]=C:\Windows\system32\DSOUND.DLL
LoadedModule[375]=C:\Windows\SYSTEM32\resourcepolicyclient.dll
LoadedModule[376]=C:\Windows\System32\Windows.UI.dll
LoadedModule[377]=C:\Windows\system32\InputHost.dll
LoadedModule[378]=C:\Program Files\Corel\Corel VideoStudio 2018\Ulprntp.dll
LoadedModule[379]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\ULPRNTPRC.dll
LoadedModule[380]=C:\Program Files\Corel\Corel VideoStudio 2018\udevmgr.dll
LoadedModule[381]=C:\Program Files\Corel\Corel VideoStudio 2018\CapMgr.dll
LoadedModule[382]=C:\Program Files\Corel\Corel VideoStudio 2018\XProfileAgent.dll
LoadedModule[383]=C:\Program Files\Corel\Corel VideoStudio 2018\MpegSettings.dll
LoadedModule[384]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\CapMgrRC.dll
LoadedModule[385]=C:\Program Files\Corel\Corel VideoStudio 2018\uvPlay.dll
LoadedModule[386]=C:\Program Files\Corel\Corel VideoStudio 2018\StopMotion.dll
LoadedModule[387]=C:\Program Files\Corel\Corel VideoStudio 2018\fr-FR\StopMotionRC.dll
LoadedModule[388]=C:\Program Files\Corel\Corel VideoStudio 2018\StopMotionUser.dll
LoadedModule[389]=C:\Program Files\Corel\Corel VideoStudio 2018\uplcpuinf.dll
LoadedModule[390]=C:\Program Files\Corel\Corel VideoStudio 2018\VFX_PLUG\NBSMEAVS.VFX
LoadedModule[391]=C:\Program Files\Corel\Corel VideoStudio 2018\VFX_PLUG\NBSamplerPack64.dll
LoadedModule[392]=C:\Program Files\Corel\Corel VideoStudio 2018\VFX_PLUG\NB3DCOVS.VFX
LoadedModule[393]=C:\Program Files\Corel\Corel VideoStudio 2018\aefilter.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
OsInfo[0].Key=vermaj
OsInfo[0].Value=10
OsInfo[1].Key=vermin
OsInfo[1].Value=0
OsInfo[2].Key=verbld
OsInfo[2].Value=17763
OsInfo[3].Key=ubr
OsInfo[3].Value=292
OsInfo[4].Key=versp
OsInfo[4].Value=0
OsInfo[5].Key=arch
OsInfo[5].Value=9
OsInfo[6].Key=lcid
OsInfo[6].Value=1036
OsInfo[7].Key=geoid
OsInfo[7].Value=84
OsInfo[8].Key=sku
OsInfo[8].Value=101
OsInfo[9].Key=domain
OsInfo[9].Value=0
OsInfo[10].Key=prodsuite
OsInfo[10].Value=768
OsInfo[11].Key=ntprodtype
OsInfo[11].Value=1
OsInfo[12].Key=platid
OsInfo[12].Value=10
OsInfo[13].Key=sr
OsInfo[13].Value=0
OsInfo[14].Key=tmsi
OsInfo[14].Value=30810
OsInfo[15].Key=osinsty
OsInfo[15].Value=1
OsInfo[16].Key=iever
OsInfo[16].Value=11.253.17763.0-11.0.105
OsInfo[17].Key=portos
OsInfo[17].Value=0
OsInfo[18].Key=ram
OsInfo[18].Value=16270
OsInfo[19].Key=svolsz
OsInfo[19].Value=446
OsInfo[20].Key=wimbt
OsInfo[20].Value=0
OsInfo[21].Key=blddt
OsInfo[21].Value=180914
OsInfo[22].Key=bldtm
OsInfo[22].Value=1434
OsInfo[23].Key=bldbrch
OsInfo[23].Value=rs5_release
OsInfo[24].Key=bldchk
OsInfo[24].Value=0
OsInfo[25].Key=wpvermaj
OsInfo[25].Value=0
OsInfo[26].Key=wpvermin
OsInfo[26].Value=0
OsInfo[27].Key=wpbuildmaj
OsInfo[27].Value=0
OsInfo[28].Key=wpbuildmin
OsInfo[28].Value=0
OsInfo[29].Key=osver
OsInfo[29].Value=10.0.17763.292.amd64fre.rs5_release.180914-1434
OsInfo[30].Key=buildflightid
OsInfo[31].Key=edition
OsInfo[31].Value=Core
OsInfo[32].Key=ring
OsInfo[32].Value=Retail
OsInfo[33].Key=expid
OsInfo[34].Key=containerid
OsInfo[35].Key=containertype
OsInfo[36].Key=edu
OsInfo[36].Value=0
FriendlyEventName=Fonctionnement arrêté
ConsentKey=APPCRASH
AppName=Corel VideoStudio
AppPath=C:\Program Files\Corel\Corel VideoStudio 2018\vstudio.exe
NsPartner=windows
NsGroup=windows8
ApplicationIdentity=BC174D08D94957D6172778ED39DD6DC1
MetadataHash=-1383235368
And more than this if i update my video card intel hd graphics 530 to th lastest version jan 2019 VS crashes at launch impossible to open.
Good luck for everybody !
ID de CAB : 0
P1 : vstudio.exe
P2 : 21.4.0.165
P3 : 5beb0845
P4 : HerDocdll.dll
P5 : 21.4.0.165
P6 : 5beb0085
P7 : c0000005
P9 :
P10 :
Fichiers joints :
Symbole d’analyse :
And also this :
Version=1
EventType=APPCRASH
ReportType=2
Consent=1
Wow64Host=34404
BootId=4294967295
TargetAsId=461
IsFatal=1
Response.type=4
State[0].Value=1
OsInfo[0].Value=10
OsInfo[1].Value=0
OsInfo[3].Key=ubr
OsInfo[3].Value=292
OsInfo[4].Key=versp
OsInfo[4].Value=0
OsInfo[5].Key=arch
OsInfo[5].Value=9
OsInfo[6].Key=lcid
OsInfo[7].Key=geoid
OsInfo[7].Value=84
OsInfo[8].Key=sku
OsInfo[8].Value=101
OsInfo[9].Value=0
OsInfo[11].Value=1
OsInfo[12].Value=10
OsInfo[13].Key=sr
OsInfo[13].Value=0
OsInfo[14].Key=tmsi
OsInfo[15].Value=1
OsInfo[17].Value=0
OsInfo[18].Key=ram
OsInfo[20].Value=0
OsInfo[24].Value=0
OsInfo[25].Value=0
OsInfo[26].Value=0
OsInfo[27].Value=0
OsInfo[28].Value=0
OsInfo[32].Key=ring
OsInfo[36].Key=edu
OsInfo[36].Value=0
ConsentKey=APPCRASH
NsPartner=windows
NsGroup=windows8
And welcome to the forums
Sorry you are having these problems
As your other post you are best in contacting Corel Support
viewtopic.php?f=1&t=64956&p=365276#p365276
Ok
First Corel have recently provided a hot fix to correct problems launching the program
Not sure that this will help in this case , but worth a try
Instructions to replace file:
1. Download file "iEncoder.dll" from here:
http://cdn.pinnaclesys.com/SupportFiles ... ncoder.zip
2. In Windows Explorer, browse to C:\Program Files\Corel\Corel VideoStudio 2018\Common Files\MPEG
3. Extract the DLL file into this folder.
4. Start Corel VideoStudio.
Thanks - please let us know how it works for you.
And if no change
Do you have any other Video Studio programs installed?
Can you un-install the program using the Cleanup tools
Reinstall the program, it may be best to download the installation files again just in case the originals are corrupt in some way?
Ok
And if no change
