How can I correct this? It has locked up my PSP. Thank you, in advance. Carl
In PSPX8 "Google Maps Javascript API does not support...
carlb123
- ram: 4gb
- Hard_Drive_Capacity: 224gb
In PSP8 "Google Maps Javascript API does not support this browser"..... Now this error message came up suddenly.
....see attachment.....
- hartpaul
- ram: 8 Gb
Re: In PSPX8 "Google Maps Javascript API does not support...
Just noticed that in 2019 the mapping comes up with for development purposes.
2018 still basically works
X8 script error.
I think Corel made a mistake when it started to use outside applications such as Google for its mapping function, same with uploading images to Facebook etc which have also had problems.
It means that when Google , Facebook etc change their landing areas or means of mapping or uploading data then it gets broken in PSP.
Then Corel has to upgrade with an Update or special hotfix to get it working again until the nexyt change by Google / Facebook etc. This means that they would have to fix many of the past versions of PSP that have the mapping function and convert them all to have one entry point at Corel that changes automatically as Google makes its changes.
I do not normally use the mapping function apart from checking problems that people find. Likewise I prefer to save the image and then load it using Facebook etc's latest upload mechanism
X8 script error.
carlb123
- ram: 4gb
I found a "work-around" solution for the problem. If you go to(and open-click on)your pictures (assuming your PSP is set to open images), the image will, in fact open the image and you bypass the script error thing, altogether.
Adam Wade
- Hard_Drive_Capacity: Green Vall
Is there a solution to this, I can't do anything while error message is up which makes the program completely useless to me.
