Fastflick Template Directory - VideoStudio 2018
ispyisail
Post by ispyisail »
Hi all
For the life of me I can't find where Fastflick Template Directory is stored in VideoStudio 2018?
BJC
Hard_Drive_Capacity: 1TB
Corel programs: Videostudio X10 and 2020
Re: Fastflick Template Directory VS 2018
Post by BJC »
You should find the templates in two different places depending on whether they were supplied with the program or added by you
one is - - C:\Program Files\Corel\Corel VideoStudio 2018\EditingStyle\InstantProject
the other is - - C:\Users\[username]\Documents\Corel VideoStudio Pro\VSPTemplate
check them both out - if you have them - each project is stored as a folder within those main folders
ispyisail
Post by ispyisail »
Thanks for that.
I'm trying to open and custom edit a default template but it won't let me open a template.
Why does this happen?
BJC
Post by BJC »
You can't edit templates in Fast Flick - it is not designed to do that - you can only add and change images and take what you get
If you want to edit a fast flick template then open VideoStudio - open the Instant Projects library and search through all the sub-folders until you find the one you want - Project 05 is in the 'custom' panel - drag it down into the timeline - there you can edit it
Then in Videostudio use "File >> Export as a template >> Fast flick template " to save it
ispyisail
Post by ispyisail »
update
To open the default template I copied the template from
Code: Select all
to
Code: Select all
ispyisail
Post by ispyisail »
Where do I find this?
Re: Fastflick Template Directory - VisualStudio 2018
When we open / run Video Studio it shows the media library
The vertical tool bar shows the Instant Projects Library as the second icon
Float your mouse over the icons for the tool tip
The instant Projects library should show your template, possibly twice as you appear to have also added it to the VSPTemplate folder and EditingStyle\InstantProject folder, hmmm
BJC
Post by BJC »
see image below
ispyisail
Post by ispyisail »
Thanks guys
My copy method worked well but I suspect the other method listed is a much better idea
I wish the VisualStudio manual had a better description of how to do this.
BJC
Post by BJC »
ispyisail wrote:Thanks guys
We are using VideoStudio - Visual Studio is a special Microsoft program
and yes the manual is not very helpful at all which is why this forum provides such a useful service
