plug-ins problem
plug-ins problem
I recently had to re-install PSPX6 and PSPX7 and now I am having trouble loading my plug-ins again. I've been using the Preferences/File location/plug-ins method to load them as I always did. But nothing is happening. I need some advice on loading my plug-ins. ~Thanks
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: plug-ins problem
Are you using the 32-bit or 64-bit version of PSP? Note that if you are using the 64-bit version that only 64-bit plug-ins will appear. Most older plug-ins are 32-bit.
- hartpaul
- ram: 8 Gb
There have already been a couple of threads on adding plugins. Did you read through these?
viewtopic.php?f=56&t=62611
viewtopic.php?f=56&t=64665
It doesn't seem to matter which one I use, 32 or 64. Now I'm off to check out those links from hartpaul.
Okay I went into my program files and pasted all my plugins into the plugin folders for X6 and X7. I also did the Preferences/File location to include those files. I now see my plugins in X6 and X7. I am happy now but did this happen because of my adding them to the correct folder in programs or because of the Preference/File location change? Or does it have to be done in both?
Thanks alot.
Thanks alot.
- hartpaul
- ram: 8 Gb
Because of the little information you have given us and the facet we cannot read your mind from a diatance it is difficult to provide any morte than general information.
Bit like telling a doctor I have a pain but not asaying any more.
To start with plug ins is a general name and there are many different types of pluging some require to be placed in a programs folder under Corel - these are usually those that come as an exe file and they do the process automatically.
Then there are other plugins that are placed in a folder inside Documents and then directing the PSP version to that .
At least you did mention what versions of PSP you were using (PSP X6 and X7) . Now which plugins were you having problems with ?
There are dozens of them and they are all old but still work. There is no way I could list them all here. Anyway, I have them loaded now, just wanted some info on the general way to load them on so you got the right word: General.
