PSP 7 folders appearing on desktop
Kathleen
Corel programs: PSP7
Post by Kathleen »
My PSP 7 stopped working recently. I googled for a solution, and forget exactly what it was, followed the instructions, and it started working again.
But now folders keep popping up on my desktop. I googled for the solution, it was go to File, Preferences, File locations. It was showing desktop, so I browsed to Program files, Jasc, and each folder individually, selected, ok.
Still dropping folders on my desktop each time I open the program.
Went back in, and even tho I selected the proper folders, it says below the path options,
"default system directory for this file type:
C:\Users\Kathleen\Desktop\Tubes
How can I fix this?
tlveik
processor: Intel Core i7-6700 3.4 GHz
ram: 16 gig
Video Card: Intel HD Graphics 530 NVIDIA GeForce GTX 745
Hard_Drive_Capacity: 1.5 TB
Monitor/Display Make & Model: Dell Ultrasharp U2414H, Dell 2007WFP
Corel programs: PSP-4, 7, X1, X2, X9, 2019
Re: PSP 7 folders appearing on desktop
Post by tlveik »
Choosing any directory in Program Files is usually a problem for most programs because Windows restricts access to Program Files. You'll likely have better results if you choose something in My Documents.
Kathleen
Post by Kathleen »
OK, I created a PSP folder in My Documents, changed folder location for Tubes to the new folder. Closed PSP. reopened it, annnd, there it is, a Tubes folder on my desktop.
ehume
processor: i7 4770k
sound_card: no_sound_card
Post by ehume »
Kathleen wrote:OK, I created a PSP folder in My Documents, changed folder location for Tubes to the new folder. Closed PSP. reopened it, annnd, there it is, a Tubes folder on my desktop.
I'm following this with some interest. I've been using PSP7 for nearly 20 years and this has never happened to me.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
I need you to open your registry editor (regedit.exe)
Go to Computer\HKEY_CURRENT_USER\Software\Jasc\Paint Shop Pro\
Select the folder for your version, and you should see a field called "DefaultWrite." The directory listed in "DefaultWrite" is where PSP creates the folders. Does it point to your desktop?
I don't have PSP7 on this machine so I'm assuming the structure is a lot like Corel's. With Corel the key is located here Computer\HKEY_CURRENT_USER\Software\Corel\PaintShop Pro\X9
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
In Jasc PSP 8 it is
HKEY_CURRENT_USER\Software\Jasc\Global
tlveik
ram: 16 gig
Post by tlveik »
In Jasc PSP 7 the location is
HKEY_CURRENT_USER\Software\Jasc\Paint Shop Pro 7\Cache\Tubes\DirName1
HKEY_CURRENT_USER\Software\Jasc\Paint Shop Pro 7\Cache\Tubes\DirName2
ram: 6 GB
Interesting, it appears PSP 7 was doing it own thing. But DefaultWrite in those PSP 7 is different from later versions, it's numerical. And appears zero index based.
EDIT: Alright I take back some of what I said.
I was able to get it to create the tubes folder. I forgot that since I wasn't running it as administrator Windows 10 uses a "VirtualStore" folder in my AppData folder to hold any changes to the Program Files file system.
I still haven't found a way to permanently change the location of the default system folder. It's still forceably changing to the Program files folder even when I edit the registry.
Kathleen
Post by Kathleen »
"I need you to open your registry editor (regedit.exe)"
I don't really know how to do this. I'm thinking of uninstalling & reinstalling.
Now I just need to find the CD.
Kathleen
Post by Kathleen »
Feeling rested this morning, so I went in to change it.
Found
Opened them all, changed desktop to Cache\Tubes, etc.
Opened PSP again, folders reappeared on desktop AGAIN. Went back into registry, the DirName1 is the correct folder. But there is a new line created showing desktop. "C:\Users\Kathleen\Desktop\Brushes"
This has happened before to other people. It happened after a Windows update, see cnet link below.
https://www.cnet.com/forums/discussions ... top-17230/
Kathleen
Post by Kathleen »
Nobody?
tlveik
ram: 16 gig
Post by tlveik »
I think the lack of responses is mostly because no one has a good idea how to correct the problem.
Could you post a screen shot of your file locations dialog box? I could try setting mine like yours to see if I can duplicate the problem.
Kathleen
Post by Kathleen »
The second line reappears no matter what I do.
Have you tried unticking the "Enable this path" box under line 2?
tlveik
ram: 16 gig
Post by tlveik »
I do see a couple problems there. Try these things:
1 Change that first line to C:\Program Files (x86)\Jasc Software Inc\Paint Shop Pro 7\Tubes
2 Change the second line to something you want to use. Something in My Documents or Documents. Use the Browse button.
3 Check the Save to path box under the second line.
