Hello
I have Corel Videostudio 2018. It says there is an update and I go to install it and at the very end it says Corel is running in the background. I don't see it running in the background as I checked. I restarted the computer and tried to run it again and same message.
Please help me update Corel.
Thank you.
update
- Davidk
- ram: 16Gb
- Hard_Drive_Capacity: 6Tb
Re: update
Unlike it's prior versions, update in 2018 is slow and looks like a failure, but it isn't.
See this link to that topic in the forums viewtopic.php?f=1&t=64616&p=363230&hili ... te#p363230
Basically you have to wait it out and probably re-start to get the install message.
Re: update
The service pack file called VS2018_SP4.exe is saved to here
C:\Users\UserName\AppData\Local\Corel\VideoStudio2018
The file is 574,032KB, at least that is what I see.
Make sure that file has downloaded and saved correctly, then you should be able to install either through the program - which will ask you to close Video Studio or manually running the file by double clicking the exe file..
Good luck
Good luck
sunshine
- motherboard: harvardpilgrim
- Corel programs: corel videostudeo 18
Re: update
I don't see that.
Re: update
Hi sunshine
Please go to Video Studio 2018 – Help – About -----Will show the version you are running
The latest version number is 21.4.0.165
What do you see?
If not that -- then you may be best to re-install the program
The Web Installer should then download the latest service pack to be installed with the program.
What do you see?
sunshine
Re: update
21.0.0.68 is what it says so I will need to reinstall it?
