Multi-trim Video won't trim
Shepdog1
- System_Drive: D
- Corel programs: VIDEO STUDIO
The Multi-trim Video feature is a powerful tool - - the scrubber will get you in the ballpark, but this will let you trim right down to the specific frame. My trim went well until the File > Save Trimmed Video part. I got an error message, "The frame size (720 x 404) of the video file does not match the settings and therefore cannot be trimmed." Can someone shed some light on this for me? Thanks!
Shepdog1
- System_Drive: D
Re: Multi-trim Video won't trim
Strange that the forum pros have nothing to offer here. What are the "settings" the error message refers to?
Speaking for my part only, I have not offered anything here since I have never, not even once, used multi-trim. I would thus also only be guessing about what the settings refer to. But my guess, FWIW, would be that VS would want to be seeing the standard frame size as the setting it would use. In this case, that would be 720 x 480 (if the video is NTSC). Since your video is 720 x 404, VS cannot recognize that as a valid "setting" and refuses to proceed.
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Where is this "save trim" ? I don't see it in my X9
Where you need to save it?
When I multi trim I just drag all the clips to a library
Panasonic X900m, VXF1
Shepdog1
- System_Drive: D
Thanks, Ken. Have you found that there is a better way to trim, or do you just have no need to trim?Ken Berry wrote:Speaking for my part only, I have not offered anything here since I have never, not even once, used multi-trim. I would thus also only be guessing about what the settings refer to. But my guess, FWIW, would be that VS would want to be seeing the standard frame size as the setting it would use. In this case, that would be 720 x 480 (if the video is NTSC). Since your video is 720 x 404, VS cannot recognize that as a valid "setting" and refuses to proceed.
Shepdog1
- System_Drive: D
After trimming, go to File > Save Trimmed Video in X8. If I could save them intact just by dragging to Library, that would be simpler. I'll try it.asik1 wrote:Where is this "save trim" ? I don't see it in my X9
I always do them one by one. In the past I used to use Save Trimmed Video, but that is rare these days. I only save the trimmed ones if I think I am going to use the clip in more than one project.Shepdog1 wrote:Have you found that there is a better way to trim, or do you just have no need to trim?
