Tried to contact Support, but that seems to be a waste of time. They proposed the following:
I point out an issue that occurs during capture. I haven's even started putting anything on the time-line, let alone been doing any form of rendering. Yet, they propose two measures that aqccording to Support's own statement has to do with editing and rendering. Frankly, not very convincing. And btw, the proposed configuration changes do not change the behaviour: VS still crashes after a DV import/capture.Enable both the "Hardware Decoder acceleration" in the "Editing Process" and the "Hardware Encoder acceleration" in the "File Creation".
• Enabling the Hardware Decoder acceleration improves the clips being used in the project and enhances the editing process.
• Enabling the Hardware Encoder acceleration improves the rendering process of the video project.
Moreover, while the files captured before the crash is sometimes playable, they are often not usable neither in VS nor in separate video players. VLC reports that "the index is broken or missing".
VS says "file format mismatch" when trying to add the captured files to a folder (import media file) and the error box includes this: [1081:1:3]
It seems there are a lot of knowledgeable in here, so now I hope someone may have a good idea...
VideoStudio is version 21.4.0.165 (64bit Ultimate), FireWire card is "VIA 1394 OHCI Compliant Host Controller", Windows 10 is version 1803 build 17134.407, Computer with Intel i7 and 16 GB RAM
