Hello All,
I am new to the forum. This is my first question. I recently downloaded PSP 2019 online after using PSP X. PSP X is completely off my machines hard drive. I cannot get my plugins to "show up" on my PSP program. My questions are:
1. Do I have to add specific DLL files to PSP 2019 before my plugins can work?
2. How do I get my plugins to show up?
Thank you for whatever help you can give me.
Simplicity (totally not technically savvy)
PSP 2019 File Location Troubles
SimplicityMD
- Monitor/Display Make & Model: ACCER
- Corel programs: PaintShop Prol 2019
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: PSP 2019 File Location Troubles
1) all plugins that worked with PSP X are 32-bit plugins. Which means they require the 32-bit version of PSP to run. Have you installed the 32-bit version of psp2019 ? And are you using the 32-bit version when you try to use the plugins?
2) Is PSP actually pointing to the folders where these plugins are installed? If you go to file-> preferences->file locations under the plugins section you can see where PSP is looking for plugins. It does not look in the same places pspX did so you want to make sure psp2019 can find them by adding their locations in the list.
SimplicityMD
I'm sorry so late in replying. Yes, your suggestion solved my problem with installing my plugins. Now, my only problem is installing the AP01 Innovations without it crashing my Paintshop Pro 2019.
