VS 2018 Service Pack 4
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
It would appear the Corel have released Service Pack 4, this is indicated whilst I reinstall VS 2018, necessary because New Blue Art Effects completely destroyed all my other New Blue packages, but is not showing yet in Patches and Updates
Re: VS 2018 Service Pack 4
I just looked at Check for Updates within VS 2018 Help. And it indicated something was available. I clicked to download and nothing happened. I started writing this, and just now I got a Windows notification saying that Service Pack 4 was available and did I want to install it. I said OK. And in the background, the download started. Eventually, after a large download, the installation started. I waited over 1 minute 45 seconds while the installation green line remained at the bottom. Then all of a sudden, it went to 100% and announced it had finished.
I now have version 21.4.0.165 -- the previous version having been 21.3.0.141.
RobertOZ
Post by RobertOZ »
Here is the list of fixes supposedly included with SP4
VSX-1426 UI interface custom set failures after installing SP3
VSX-1421 Transition moved, project duration changes after changing project properties
VSX-1433 Timeline duration changes from 10 minutes to over 1 hour
VSX-1399 Auto-alignment feature does not center correctly
VSX-1425 Options panel won't work if switch back to edit from Share
VSX-1427 Poor quality render using Smart Proxy
VSX-1428 Mpeg-4 export problems, reported on forums [Asik et al]
VSX-1430 PAL installation shows share Mpeg4 as NTSC profile
VSX-1432 Crash when adding overlay effect to clip with NB Titler Pro 5
VSX-1444 Can't remove sample video thumbnails
VSX-1446 Set Welcome book page colors, when offline
VSX-1440 Provide user message when selecting share to Facebook
You will need to make your own assessment as to the accuracy of the above, but VSX-1426, VSX-1433 have definitely been fixed
john4647
processor: Intel i7 6700 340ghz
Video Card: NVIDIA GeForce GT 720
sound_card: NVIDIA
Hard_Drive_Capacity: 1TB SSD +
Monitor/Display Make & Model: Dell 24"
Corel programs: VS 2021 ULT, PSP 2023 ULT, VS2023 ULT, +
Post by john4647 »
Just loaded SP4 with the same scenario as Ken.
My NB titler problem (VSX 1432) seems to be cured.
On the down side, the transitions (A/B) are now in what appears to be a random order on the screen, with no option to sort A to Z.
Post by BrianCee »
Installed without problems - my transitions are still in correct alphabetical order
pepegota
motherboard: ASUS TUF Z390-Plus
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Ben Q, "21" LCD
Corel programs: VS 2018, VS 2019, VS 2020
Post by pepegota »
This update system, with its delays, is not good. Corel should change it. I clicked update 20 minutes ago and I am still waiting.
How long did you have to wait? Can I reinstall the program thus, obtaining the new update?
Post by BrianCee »
After you have downloaded the update - shut down Videostudio - then restart it again - you then get asked if you want to install the upgrade - and then have to shut VS down again -- ten there is quite a long wait with a littl bit installed before it eventually rushes to the end
no need to un-install
pepegota
ram: 64 GB
Post by pepegota »
That's the problem-no download. I checked and I can reinstall the program with the new service pack 4. What a way to go!!!
At least there will be something happening-this system is bad!!!
Post by BrianCee »
After I clicked to download the programme nothing appeared to happen - - nothing apparent anywhere - but restarting VS kicked it into action
pepegota
ram: 64 GB
Post by pepegota »
I also just restarted and it worked. Just before I was considering a complete reinstall. Still not a good system!
Jan
motherboard: ASUSTeK MAXIMUS IX HERO
processor: Intel Core i7-7700K 4.20GHz
ram: 16 GB
Video Card: ASUS NVIDIA GeForce GTX 1060 6GB
Hard_Drive_Capacity: 6.5 TB
Monitor/Display Make & Model: Samsung TV 40" 1920 x 1080
Corel programs: CVS 2020 version 23.2.0.587
Post by Jan »
For those who would like to know where this and former updates files are stored :
C:\users\Your user name\AppDate\Local\Corel\Videostudio2018\VS2018_SP4.exe. (574 MB)
The bug from SP 3 with the low resolution rendering when using Smart proxy Manager seems now to be fixed in SP 4 (verified).
john4647
sound_card: NVIDIA
Post by john4647 »
BrianCee wrote:Installed without problems - my transitions are still in correct alphabetical order
Is the A to Z option still at the top of the A/B transition screen?
john4647 wrote:Just loaded SP4 with the same scenario as Ken.
Hi John
Like Brian I did not have a problem with the order of the A / B transition library
There has never been an active sort order option for the A / B although there is an icon which is greyed out.
This has happened before that the order of clips do get mixed up but usually the names shift, example the 3D Confetti shows on the Accordion clip.
You may have to do a reset by renaming the 21.0 folder to fix this.
More info here:-
http://lata.me.uk/corel/reset/reset.htm
As a thought :idea: you could try re-installing the service pack SP4 to see if that cures the listing?
gewb
motherboard: MSI Pro B550-VC
processor: AMD Ryzen 7 5700X
Video Card: ASRock Radeon RX 6650 XT
Monitor/Display Make & Model: LG 24MK430
Corel programs: 2018, 2021, 2023 Ult.
Post by gewb »
john4647 wrote:On the down side, the transitions (A/B) are now in what appears to be a random order on the screen, with no option to sort A to Z.
Mine show in alphabetic order.
john4647
sound_card: NVIDIA
Post by john4647 »
Hi John
More info here:-
Hello Trevor, tried re-installing SP4 but this made no difference.
However resetting 21.0 did cure the problem (well niggle, really).
I now have six different 21.0 folders (old 1, old 2 etc.) but my programme is behaving.
Thanks once again
