Crop box stays on
lbabus
Crop box stays on
Post by lbabus »
After I crop a photo and save the changes and go to the next photo the crop box shows up on the next picture.. The crop button stays highlighted on the vertical toolbar. How do I turn it off?
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Crop box stays on
Post by Jean-Luc »
Go to Preferences / Transparency and shading / uncheck Automatically show crop rectangle
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Post by MarkZ »
lbabus wrote:After I crop a photo and save the changes and go to the next photo the crop box shows up on the next picture.. The crop button stays highlighted on the vertical toolbar. How do I turn it off?
It may be that you have not gone to a different tool when you go to the next photo. For example, select the Pan tool (the hand icon).
Mark
lbabus
Post by lbabus »
Thank you both! Any way to see both the before image and the after image on the same screen at one time for a side by side comparison?
Jean-Luc
Post by Jean-Luc »
The side by side comparison is only available for some tools in the Edit mode.
patara
motherboard: ASUS Prime Z690 DDR5
processor: Intel i7-12700K CPU 12 Core
ram: 32 GB
Video Card: GeForce GTX 1060 GI Gaming 6G
sound_card: VIA High Definition Audio
Hard_Drive_Capacity: 1TB SSD +22TB Hard Drives
Monitor/Display Make & Model: Dell U2715H
Corel programs: PSP7 to PSP 2023
Post by patara »
lbabus wrote:Thank you both! Any way to see both the before image and the after image on the same screen at one time for a side by side comparison?
When I want to compare changes I duplicate the image by using Shift+D, and then sit the two images side by side.
Jean-Luc
Post by Jean-Luc »
lbabus wrote:Any way to see both the before image and the after image on the same screen at one time for a side by side comparison?
Are you working in Manage, Adjust or Edit mode ?
In Adjust mode, when you make the settings, clicking on the "Show original" button on screen's bottom permits to see the image "before".
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Are you here referring to the crop tool again or have you changed midstream and asking a general question.
If the crop tool then Crop as new Image will keep your original image visible and also show you the cropped image.
At any time when you have an image loaded you can drag the layer thumb to the empty workspace and create a copy.
Then you can operate on thatt copy and compare changes to the origina; by choosing Windo > Tile Horizontally
ehume
processor: i7 4770k
sound_card: no_sound_card
Post by ehume »
This has been a feature of PSP since at least PSP7 (the earliest version I have on my machine). On the Menu Bar, select "windows." Go down to "Tile vertically" and you will have side-by-side views of whatever images you have opened.
