Crop bounces back to center of photo when zoomed
Kusaywa
motherboard: Asus P5QL-Pro
processor: Core Quad 6700
ram: 8gb
Video Card: Nvidia
Hard_Drive_Capacity: 1tb
Corel programs: Paintshop Pro 2019
Post by Kusaywa »
If I have a photo zoomed in and I attempt to move the crop box, say on the bottom of the photo, the grid line jumps to the center of the photo. On previous versions of PSP, it allowed you to make precise crops while zoomed in. Unfortunately now, you have to have the photo in full view to adjust the crop lines on all ends. Can this be fixed like previous versions? Is there a setting? Thanks
ehume
processor: i7 4770k
sound_card: no_sound_card
Re: Crop bounces back to center of photo when zoomed
Post by ehume »
What version (or year) of PSP?
In his Profile below the avatar, he has X9 listed (though he calls it 19).
Kusaywa
ram: 8gb
Video Card: Nvidia
Post by Kusaywa »
2019
Kusaywa
ram: 8gb
Video Card: Nvidia
Post by Kusaywa »
Just noticed this problem has been around since the 2018 version and still hasn't been fixed. Anybody know a work-around?
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Is it fixed with the new update to 2019?
JoeB
Using PSP 2019 64bit
Kusaywa
ram: 8gb
Video Card: Nvidia
Post by Kusaywa »
I'm on 21.0.0.67 and it says that it's the latest version. Where do I get this update?
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
You go to the Corel site corel.com and under Support choose patches and updates and then Paintshop pro
https://www.paintshoppro.com/en/support ... duct-tab=0
Kusaywa
ram: 8gb
Video Card: Nvidia
Post by Kusaywa »
When I try to install the update it says I'm already on the latest version???
hartpaul
ram: 8 Gb
Post by hartpaul »
The original program I installed on second August was v21.0.0.119.
I have seen different versions claimed after an update including
21.1.0.8
21.1.022 (miss type as should be four numbers separated by full stops.
and most commonly
21.1.0.22 which seems to be the correct update.
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
JoeB wrote:Is it fixed with the new update to 2019?
It appears to be; at least if I understand correctly what the OP's issue is. I zoomed in on an image, set up a crop and them was able to move the crop all around the image.
Kusaywa
ram: 8gb
Video Card: Nvidia
Post by Kusaywa »
If you zoom in on the image, where you can't see most of it, then use the "scrolls" to go to any edge and try to adjust the crop line, it jumps to the center of the image. At least on mine it does.
hartpaul
ram: 8 Gb
Post by hartpaul »
If I may illustrate
1. Load a test image mine is 800 x 533 pixels and then using a paintbrush paint a black cross so you can see the center point of the image.
2. Place a crop rectangle that is off center say top left.
At this point the centre point is visible .
3. Now zoom in so that the centre is off screen and try and drag the lower diagonal of the crop rectangle to make it smaller or larger.
4. Bingo the window jumps dragging your cursor so that the center point is visible again.
So the question is does the update at least stop this from happening? Much of these problems are because as a part of the new crop behavioue there is an area placed aroungd the image to allow rotating of the image.
Kusaywa
ram: 8gb
Video Card: Nvidia
Post by Kusaywa »
Thanks for the pics, hartpaul, that's exactly what it does. But when I try to install the update, it says I'm on the latest version. And when I try to update from PSP, it says no updates available.
hartpaul
ram: 8 Gb
Post by hartpaul »
In that case if the number is not showing as 21.1.0.22 and it will not allow you to update then might be best to uninstall and then use the clean up tool from here
viewtopic.php?f=56&t=52337
Then download a fresh instalation file and reinstall and then check if the number is correct.
