Converting gradiants
Katn
motherboard: intel
ram: 12G
Hard_Drive_Capacity: 1TG
Monitor/Display Make & Model: Gatweay
Corel programs: PSP Ultimate package
Post by Katn »
Its been a few years since I have used PSP. I purchased 2019 Ultimate. I have some gradients that I want to use, they are JPG. what does the extension need to be and how do I convert them? I remember there was a way.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Converting gradiants
Post by LeviFiction »
As far as I know there is no way built into PSP to convert an image into a gradient. You just have to manually select each color point from the image and use those to create a gradient in the gradient editor. Or find a program/plugin that can convert an image into a gradient.
There used to be this gradient map plugin that would allow you to draw a line over your image and it would create a gradient of all the colors it found. You could then export it as a .grd file which I believe PSP can import. You can also try any number of online image to gradient converters. Though I think most if not all simply convert to CSS or similar. Still they would give you all of the color stops you need.
PSP can import Photoshop gradient files and it can use it's own PSPGradient files. But it has no method for auto-converting images to gradients.
Out of curiosity, do you have an example image you can post here?
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
Katn wrote: I have some gradients that I want to use, they are JPG.
You may use a JPG image as a Foreground color. It is not gradient but sometime, it may help...
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
The OP stated that they had some jpg images that were gradients and wanted to convert them to PSP gradients. This is not too onerous a task as shown below.
Making a gradient from an Image
This shows one way of converting a jpg image gradient into a PSP Gradient.
1. Load an image that contains a gradient you want to convert. Crop the image as shown to include the best parts of the gradient area.
2. Take the crop and rotate it left or right depending on where you want the colors to appear.
Using the 2019 Materials Properties
1. This almost innocuous + sign is how you start and name a new gradient. In the Classic Materials properties it is an Edit button, the + does not give any message when you mouse over it, not a New Gradient, not an Edit, Nada. This is the Corel improvement!!!!??
2. Type in a name for the new gradient
3. Click OK
Steps for each gradient marker
1. Click the marker to make it active (top turns black) or click a blank area to make a new active marker.
2. Click the second box to the right of User (again unidentified in a mouseover). This opens the color wheel to make it and the cursor active in choosing a color.
3. You can now click a corresponding point in the slice of your image to choose the color there.
4. Click the OK button to close the Color box and allow you to choose a new marker for the next color.
So it requires 4 steps for each marker. Yes this is an improvement on the Classic Materials Properties Dialog --- NOT!!??
Choosing the Classic Materials Properties box.
This was at least one of the good things that Corel has done allowing users to use the old tried and true Classic Material Properties .
Tick the box (File > Preferences > General Program Preferences > Palettes)
hartpaul
ram: 8 Gb
Post by hartpaul »
Cont.
Using the Classic Materials Properties dialog and Gradient Editor.
This image shows the Gradient Editor from the Classic Materials Properties
1. Click New for new gradient = Clicking that + sign in the other version.
2. Type in the new name
3. Click OK to reserve a space for that new gradient.
This is essentially the same as the New Gradient dialog in the Newer Materials Properties > Gradient
Choosing your gradient colors in the Classic Editor
Now this is where the classic editor shines
1. Choose the marker
2. Click in the image
3. Choose the next marker etc
Two steps only to give a marker a color compared with 4 steps with the new improved Materials Properties Gradient Editor.
At the end click OK and confirm that you want this edited gradient to overwrite the new name you typed in.
Katn
motherboard: intel
ram: 12G
Post by Katn »
Thank you all! I will try what you suggested!
Jean-Luc
Post by Jean-Luc »
Katn wrote:I have some gradients that I want to use, they are JPG.
Hi Katn,
could you explain from where your gradients are coming in JPG ?
