how to get rid of the PSP fingerprint in binary Jpeg files?
Michael REMY
- motherboard: asus p6t
- processor: intel core i7 980
- ram: 12GB
- Video Card: nvidia quadro K2000
- sound_card: creative soundblaster xfi pro titanium
- Hard_Drive_Capacity: +1TB SSD
- Monitor/Display Make & Model: samsung bw226 desktop 1680x1050px
- Corel programs: Corel PSP 2018 Pro
hi,
i noticed that when i saved an edited picture with PSP2018, the datetime and the sofware named is written into the binary itself !
so, when i include the jpeg file in another binary files (like .exe or mp3 tag art album....), then i can see it again !
is this an option ?
how to desable that ?
Thanks for the help.
is this an option ?
i'm a Paintshop pro user since 1999 on windows 3.11 until now with psp2018 on Win7 X64
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: how to get rid of the PSP fingerprint in binary Jpeg fil
Do other softwares the same thing (Photoshop, Affinity, ACDSee, etc.) ?Michael REMY wrote: i noticed that when i saved an edited picture with PSP2018, the datetime and the sofware named is written into the binary itself !
Michael REMY
- ram: 12GB
i discover it is storend in the exif infos.
what i don't want, is PSP add exif in files which does not come from camera !
When i create a picture, once it is saved , it contains EXIF infos !!! not normal at all.
- ehume
- motherboard: Gigabyte GA-Z87X-UD4H
- processor: i7 4770k
- Video Card: Intel HD4600 [iGPU]
- sound_card: no_sound_card
- Hard_Drive_Capacity: 512GB+4TB
- Monitor/Display Make & Model: Acer KN242HYL
- Corel programs: PSP 2018 32b & 64b, AS3 64b, PE5 64b
It sounds like the software is being honest: "Hi. I was processed by PSP."
Kathy_9
- Hard_Drive_Capacity: 2TB
See if changing the following setting helps.
Michael REMY
- ram: 12GB
i tried, it does not concern the EXIF information, only the history text stored.Kathy_9 wrote:See if changing the following setting helps.
PSP should have an option to let the user decide when he want this infos :
- never
- only from camera pciture
- ask on demand
- hartpaul
- ram: 8 Gb
When you do Save As go to Options and then untick save Exif informtion and any reference to PSP is not saved. so works for any graphic not from camera.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
You can't turn off adding the program name in PSP without removing all EXIF data.
However, you can remove this EXIF data using Windows own properties dialog.
Michael REMY
- ram: 12GB
it works but it is boring ! requierts time and clic ! i have to do it each time !hartpaul wrote:When you do Save As go to Options and then untick save Exif informtion and any reference to PSP is not saved. so works for any graphic not from camera.
the correct feature should be to not add an exif info when there is not, and let the user chose himself the behavior when there is already one.
Michael REMY
- ram: 12GB
it would be good that PSP can display the size of the metatag exif the whole metadata stored in a image file because it can begin bigger that the file itself.
When you broadcast image to the internet through a limited speed, you neet to care about the bandwith (which is not free), so psp should alert the user , it could be a good feature.
Imagine the meta size of a picture you work on everyday....
The worst situation is when you embeded the file into another one (.exe, android application apk, or music file as album art cover..)
Jean-Luc
Saving history is only supported by JPG, TIFF and pspimage.Michael REMY wrote: the correct feature should be to not add an exif info when there is not, and let the user chose himself the behavior when there is already one.
If you save in another file format, the history will be deleted (PNG for example).
You may also save as X3 compatibility (history will be removed).
- ehume
I was going to ask How do you do that? but I kept digging. In PSPx10 (2018) in the Save As dialogue, I see choices of PSPimage and PSP Animation Shop under "Options." When I click the "Options" button for PSPimage I get another dialogue. Within that dialogue, there is a "Version" button that allows me to choose PSP 5 to PSPx8 -- a long list. Hats off to Corel for providing such customizability, and hats off to you for knowing about it. You showed us an easy way to accomplish OP's wishes.Jean-Luc wrote:Michael REMY wrote: . . . You may also save as X3 compatibility (history will be removed).
One question -- when I choose PSP Animation Shop, when I click the "Options" button I get choices of "Run length encoding," "LZ77 encoding" and "Uncompressed." Do you know what those options are?
Jean-Luc
They are different ways to compress (or not) the saved file :ehume wrote: One question -- when I choose PSP Animation Shop, when I click the "Options" button I get choices of "Run length encoding," "LZ77 encoding" and "Uncompressed." Do you know what those options are?
https://en.wikipedia.org/wiki/Run-length_encoding
https://en.wikipedia.org/wiki/LZ77_and_LZ78
