No Audio
DanG
No Audio
I know that similar questions have been asked in the past but I am still having problems with the audio in my project.
I have recorded some old VHS tapes onto DVD using a stand alone DVD recorder. These play fine on stand alone DVD players and on my PC.
I now want to edit the DVDs and so purchased the full version of VS9 as I understood that this would accecpt the Dolby Digital audio on the DVDs. I can import the video no problem but there is no audio (it does show it in the properties of the clip, though). I have checked the codecs and the Dolby Digital one is present. I've also tried burning the project back onto a DVD and there is still no audio. Reinstalling the software does nothing, either.
If anyone has any ideas I'd really appreciate it.
thanks.
thanks.
DanG
DanG
I have tried several different clips from several different DVDs and the problem is the same. The properties are as follows:
File Format: PAL DVD
File Size: 57,550kb
Duration: 300.400 seconds
Video Type: MPEG-2 video
Total Frames: 7510
Attributes: 24 bits, 352x288, 4:3
Data Rate: variable bit rate (max 1380 kbps)
Audio Type: Dolby Digital Audio
Total Samples: 14,419,200
Attributes: 48000Hz, 2/0 (L,R)
Layer: None
Bit Rate: 128 Kbps
File Size: 57,550kb
Total Frames: 7510
Layer: None
Bit Rate: 128 Kbps
maddrummer3301
maddrummer3301
Maybe a problem with the audio being a low bit-rate or something.
Looks like the videos recorded in a mode for 4 hours or greater.
Try the Standard Recording mode or High Quality.
The audio bit-rate should be 256kbs in those modes.
The files import and work on my system with dolby at 256kbs.
Hope this helps,
MD
Hope this helps,
MD
Paully01
Hi I am having same problem when trying to import video from DVD, I am using VideoStudio 8. I use the insert DVD/DVD-VR option & open disc & Video TS folder then select clips & finish, the video imports ok & if I open files you can see the audio track within the video file but no sound when played back, below is file info
Video :
MPEG-2 Video
4:3 Ratio
352 x 576 Size
1944 Frames
9300 Kbits/sec
Audio :
Dolby AC-3 Audio
stereo Mode
48.00 kHz
2 Channel(s)
Video :
MPEG-2 Video
4:3 Ratio
352 x 576 Size
1944 Frames
9300 Kbits/sec
Audio :
Dolby AC-3 Audio
stereo Mode
48.00 kHz
2 Channel(s)
lancecarr
- ram: 12GB
- Hard_Drive_Capacity: 700GB
Paully01
